楼主: trashio
SynopsysMonoSlayer v24.09 request
发表于 2024-10-25 11:00:06 | 显示全部楼层
basically OK,
H$pice, Fine$im, x@ can work Rocky8, not work Rocky9
点评
thanks  发表于 2024-10-25 19:43
发表于 2024-10-25 15:09:45 | 显示全部楼层
Thanks for sharing
发表于 2024-10-25 16:43:48 | 显示全部楼层
感谢分享
发表于 2024-10-25 22:45:18 | 显示全部楼层
kankan
发表于 2024-10-26 12:03:02 | 显示全部楼层
感谢分享
发表于 2024-10-27 01:16:31 | 显示全部楼层
谢谢分享
发表于 2024-10-27 18:00:01 | 显示全部楼层
After completing the installation of RHEL 9.4, I tested SynopsysMonoSlayer. Like the previous pubkey_verify 1.6, it allows hspice_v2024.9 to run, but a crash file is generated with the message "error invalid memory reference." SynopsysMonoSlayer was released before the distribution of hspice_v2024.9 and does not fully cover S company's new protection mechanisms.
In conclusion, due to the error message, it lacks reliability across all other 2024 versions, making it no different from the previously used pubkey_verify 1.6. As a result, it is ultimately unusable.
发表于 2024-11-3 23:51:09 来自手机 | 显示全部楼层
謝謝分享
发表于 2024-11-4 12:45:28 | 显示全部楼层
什么版本
发表于 2024-11-4 12:49:38 | 显示全部楼层
joshua2784920 发表于 2024-10-27 18:00
After completing the installation of RHEL 9.4, I tested SynopsysMonoSlayer. Like the previous pubkey ...
Hi joshua,
Do you try patch it only use SynopsysMonoSlayer?
GMT+8, 2025-10-16 02:10 , Processed in 0.019507 second(s), 4 queries , Gzip On, Redis On.
