查看: 1539|回复: 6
[求助] skill GUI
发表于 2024-10-22 16:41:03 | 显示全部楼层 |阅读模式
如下图所示绿色框框的label field对应的procedure name是什么
发表于 2024-10-23 08:50:41 | 显示全部楼层
CIW窗口应该可以看到吧
 楼主| 发表于 2024-10-23 09:13:47 | 显示全部楼层
狱火虫 发表于 2024-10-23 08:50
CIW窗口应该可以看到吧
产生这个field的命令是什么
发表于 2024-10-23 09:41:22 | 显示全部楼层
hiCreateFrameField
hiCreateFrameField(
?name s_fieldName
[ ?labelText t_labelText ]
[ ?enabled g_enabled ]
[ ?invisible g_invisible ]
=> r_fieldHandle
Description
Creates a frame field for a two-dimensional form. A frame field is a border that surrounds a group of related fields so they are easier to see.
If t_labelText is specified and you specify 2D attributes for the frame field, you must also specify the label height in the 2D attributes even though the value is ignored. For example:
list( r_framefield x_xpos:x_ypos x_width:x_height x_labelHeight)
Arguments
?name s_fieldName
Handle to the frame field.
Title of the frame field. If the title is specified it appears in the upper left corner of the frame. The title must not extend beyond the width of the frame.
?enabled g_enabled
Specifies whether the fields in the layout are enabled. The default value is t.
Specifies whether the layout and the fields within are invisible. The default value is nil.
Value Returned
r_fieldHandle
Field handle for the frame field.
发表于 2024-10-23 09:56:54 | 显示全部楼层
amodaman 发表于 2024-10-23 09:41
hiCreateFrameField
hiCreateFrameField(
skill 领域大神
发表于 2024-10-23 10:12:36 | 显示全部楼层
hiCreateFrameField()
发表于 2024-10-23 10:34:04 | 显示全部楼层
hzyf 发表于 2024-10-23 09:56
skill 领域大神
我都不是专业干SKILL的,自己熟而已
GMT+8, 2025-9-30 17:25 , Processed in 0.016936 second(s), 4 queries , Gzip On, Redis On.
