查看: 6744|回复: 46
[资料] Cadence RAK : Operational Amplifier (OpAmp) Measurements from ADE Explorer
发表于 2024-10-21 11:57:54 | 显示全部楼层 |阅读模式
Operational Amplifier (OpAmp) Stability, CMRR, PSRR, Noise, Slew Rate, THD, Compression Distortion Measurements from ADE Explorer
This RAK introduces OpAmp Stability, CMRR, PSRR, Noise, Slew Rate, THD, and Compression Distortion Measurements setup examples. These are very simple examples that can be easily understood. The document helps you understand the usage of ac, stb, noise, tran, and xf analysis to measure the various OpAmp design specifications based on different testbench setups.
OPAMP_RAK.tar.gz
1.14 MB, 下载次数: 339 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Operational_Amplifier_Measurements_RAK_ADE_Explorer_SpectreX.pdf
3.35 MB, 下载次数: 488 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2024-10-21 14:37:46 | 显示全部楼层
thanks for sharing
发表于 2024-10-21 14:38:42 | 显示全部楼层
楼主辛苦了
发表于 2024-10-21 14:50:35 | 显示全部楼层
谢谢分享
发表于 2024-10-21 15:33:35 | 显示全部楼层
谢谢分享!
发表于 2024-10-21 21:02:13 | 显示全部楼层
thanks
发表于 2024-10-21 22:58:43 | 显示全部楼层
Thanks!!!
发表于 2024-10-21 23:44:48 | 显示全部楼层
Thanks
发表于 2024-10-22 08:57:56 | 显示全部楼层
感谢分享
发表于 2024-10-22 09:04:09 | 显示全部楼层
学习下,感谢分享。
GMT+8, 2025-12-25 07:35 , Processed in 0.970342 second(s), 4 queries , Gzip On, Redis On.
