查看: 1105|回复: 3
Virtuoso AMS simulation digital signals become invalid in simvision
发表于 2024-10-18 16:23:14 | 显示全部楼层 |阅读模式
Hi
I'm running AMS simulation with Virtuoso, APS++, Spectre+Xcelium.
I need to stop the simulation sometimes. However, everytime I do this, the digital signals from RTL code will become "invalid" in simvision.
Does anyone know how to solve this issue?
Is this related to the output format? I'm using SST2
Thank you.
发表于 2024-10-18 17:33:54 | 显示全部楼层
run -sync
try this command after you pause your simulation, before you reload the waveform GUI
 楼主| 发表于 2024-10-19 07:28:35 | 显示全部楼层
工大鱼肉 发表于 2024-10-18 17:33
run -sync
Hi
Thank you for prompt response.
I try to type "run -sync" in CIW, but it doesn't work. I still see the new signals "No Value Available".
Can you specify where to type this "run -sync"?
发表于 2024-10-19 18:42:01 | 显示全部楼层
sorry for no more advice, for I did not do this these months, and I don't have a environment
GMT+8, 2025-12-24 19:18 , Processed in 1.538604 second(s), 3 queries , Gzip On, Redis On.
