查看: 1223|回复: 2
[求助] dc综合问题
发表于 2024-10-14 17:12:20 | 显示全部楼层 |阅读模式
顶层有四个模块,如果我不想对CMP,Coarse_EN_Cell,Fine_EN_Cell进行优化,set_dont_touch命令应该怎么写呢?
顶层代码:
module    DLDO
( input  VREF,
  input  CLK ,
  input  RSTN,
  input  VIN ,
  output VLOAD
wire  COMP, VOUT1, VOUT2;
wire  [63:0]  COUT;
wire  [63:0]  FOUT;
CMP  u0
( .CLK  (CLK  ),
  .VREF (VREF ),
  .VLOAD(VLOAD),
  .COMP (COMP ),
  .VOUT1(VOUT1),
  .VOUT2(VOUT2)
Coarse_Fine_Ctrl u1
( .CLK  (CLK  ),
  .COMP (COMP ),
  .VIN_1(VOUT1),
  .VIN_2(VOUT2),
  .RSTN (RSTN ),
  .COUT (COUT ),
  .FOUT (FOUT )
Coarse_EN_Cell u2
( .DATA (COUT),
  .VIN  (VIN),
  .VLOAD(VLOAD)
Fine_EN_Cell u3
( .DATA (FOUT),
  .VIN  (VIN),
  .VLOAD(VLOAD)
endmodule
发表于 2024-10-14 17:42:48 | 显示全部楼层
set_dont_touch [get_cells {u0 u2 u3}]
 楼主| 发表于 2024-10-15 08:36:27 | 显示全部楼层
成功了,感谢
GMT+8, 2025-12-20 18:43 , Processed in 0.012399 second(s), 3 queries , Gzip On, Redis On.
