查看: 2913|回复: 10
[求助] ADE Explorer 仿真求助
发表于 2024-8-24 20:10:40 | 显示全部楼层 |阅读模式
QUESTION (EXPLORER-1921): Failed to start new job after 3 attempts. Possible reasons could be1. The machine selected in the current lob Setup Policy is not reachable.2. The Cadence hierarchy is not detected, not installed properly ornot compatible on the machine selected in the current job Setup Policy.3. job start script /home/techlib/smic180/PDK/1 P6M/.tmp_master/.cmddir0/swifjob39 is not found on the remote machine(s)
Do you want to retry with the current setup?
求助各位前辈和大佬,这个仿真问题是怎么出现的呀,怎么解决呀?
仿真失败
仿真失败
 楼主| 发表于 2024-8-24 20:12:11 | 显示全部楼层
求助求助
发表于 2024-8-24 22:08:21 | 显示全部楼层
以前遇到过,重启一下virtuoso就行了
发表于 2024-11-19 13:51:22 来自手机 | 显示全部楼层
同样的问题,解决了吗
发表于 2024-12-10 14:22:44 | 显示全部楼层
同问
发表于 2025-1-9 11:50:21 | 显示全部楼层
同问
发表于 2025-1-17 17:20:08 来自手机 | 显示全部楼层
今天也遇到这个问题,但是还没有找到解决办法
发表于 2025-3-11 09:48:58 | 显示全部楼层
请问解决了吗
发表于 2025-3-11 09:49:53 | 显示全部楼层
请问解决了吗
发表于 2025-3-11 09:50:50 | 显示全部楼层
请问解决了吗 最后是怎么处理的呢
GMT+8, 2025-12-14 10:17 , Processed in 0.020270 second(s), 4 queries , Gzip On, Redis On.
