查看: 2048|回复: 3
[求助] Cadence在仿真后,出现了这样的警告,怎么改呀
发表于 2024-8-3 16:13:50 | 显示全部楼层 |阅读模式
*WARNING* (GE-2067): geComputeQueryBbox: There is no graphical edit environment assigned to window(118) because the window is not a graphic editor window.
Make sure that your current window is a valid graphic editor window.
If it is a valid graph editor window, contact customer service to investigate this issue.
*Error* geqp: can't handle (-0.9375 >= nil)
发表于 2024-8-3 19:39:54 | 显示全部楼层
调用geComputeQueryBbox ,它的返回值为 nil。试试geOpen(?window win1 ?lib "opamp090" ?cell "adc_sample_hold" ?view "layout_final")
发表于 2025-6-22 17:07:00 | 显示全部楼层
请问解决了吗?如何解决
发表于 7 天前 | 显示全部楼层
请问如何解决?
GMT+8, 2025-10-18 13:01 , Processed in 0.015389 second(s), 5 queries , Gzip On, Redis On.
