查看: 1134|回复: 1
[讨论] vivado的timing violation
发表于 2024-7-26 12:05:41 | 显示全部楼层 |阅读模式
有violation也能用吗
发表于 2024-7-26 15:31:12 | 显示全部楼层
Check please in which corner you have problems: I found out that when 3 of 4 corners is good — the design is working okay on the board. By default Vivado check both models (fast and slow). Open "Report Timing Summary" in Implementation and check in settings min or max separately
GMT+8, 2025-12-20 10:48 , Processed in 0.066904 second(s), 6 queries , Gzip On, Redis On.
