查看: 1488|回复: 5
virtuoso 运行24小时后自动关闭
发表于 2024-7-17 09:32:55 | 显示全部楼层 |阅读模式
sysconf:6   mesa-libGL             9.2        0.5            -                       i686        FAIL    Package not installed.
sysconf:->        ----------------------
sysconf:->  'Mesa libGL 32bit'
sysconf:7   mesa-libGL             9.2        0.5            11.0.7-4.el6            x86_64      PASS
sysconf:->  'Mesa libGL Library'
sysconf:8   mesa-libGLU            9.2        0.5            -                       i686        FAIL    Package not installed.
sysconf:10  openmotif22            2.2.3      19             -                       i686        FAIL    Package not installed.
sysconf:->  'openmotif-32bit'
sysconf:11  openmotif22            2.2.3      19             -                       x86_64      FAIL    Package not installed.
sysconf:->  'openmotif'
sysconf:37  apr-util               1.3.9      3              1.3.9-3.el6_0.1         x86_64      PASS
sysconf:->  'APR Utility library 64 bits'
sysconf:38  xorg-x11-server-Xvfb   1.13.0     23             1.10.4-6.el6            x86_64      FAIL    Old release version
sysconf:->        installed.
sysconf:#   WRITABLE-FILE                           Exists    Status  Info
sysconf:-   -------------                           ------    ------  ------------
sysconf:1   /dev/shm                                YES       PASS    edpSharedMemory
sysconf:Configuration checks failed on this workstation (login02), status is: FAIL
发表于 2024-7-17 09:44:49 | 显示全部楼层
你这好多包没装啊
 楼主| 发表于 2024-7-17 13:41:06 | 显示全部楼层
wsid 发表于 2024-7-17 09:44
你这好多包没装啊
装了,都能正常运行24小时了,不知道什么原因报出这个错误!
 楼主| 发表于 2024-7-19 09:18:15 | 显示全部楼层
sysconf:Validating WRITABLE-FILE .....1 to check
sysconf:Normal exit. This workstation (login02) status is: PASS
sysconf:Host login02 has a Cadence supported Linux configuration.
sysconf:Exiting checkSysConf ... Good-bye
sysconf:Output is saved as /tmp/checkSysConf.login02-2024.07.19.03:58.53368.log
那些Fail的安装包安装后,软件还是会自动关闭
发表于 2024-7-23 14:18:11 | 显示全部楼层
换个版本试试
 楼主| 发表于 2024-7-28 20:14:29 | 显示全部楼层
谢谢提示!
GMT+8, 2025-12-25 07:45 , Processed in 0.018145 second(s), 4 queries , Gzip On, Redis On.
