查看: 2175|回复: 4
xcelium 1704, 2210 sim都出现如下错误,请问跟crack有关吗?
发表于 2024-7-8 22:00:27 | 显示全部楼层 |阅读模式
xcelium> source /proj/XCELIUM1704/tools/xcelium/files/xmsimrc
xcelium> run
xmsim: *F,INTERR: INTERNAL EXCEPTION
Observed simulation time : 0 FS + 0
The tool has encountered an unexpected condition and must exit.
Contact Cadence Design Systems customer support about this
problem and provide enough information to help us reproduce it,
including the logfile that contains this error message.
  TOOL:        xmsim        17.04-s004-20170504
  HOSTNAME: lf002
  OPERATING SYSTEM: Linux 4.18.0-553.el8_10.x86_64 #1 SMP Fri May 10 15:19:13 EDT 2024 x86_64
  MESSAGE: T(0): sv_seghandler - trapno -1 addr(0xb7010e4)
        Stream rts_xfer
csi-xmsim - CSI: Cadence Support Investigation, sending details to /proj/DIflow/di/eval/flow/tessent_example_hierarchical_flow_v2021.4/wrapped_cores/processor_core/5.generate_atpg_patterns/xmsim_36072.err
csi-xmsim - CSI: investigation complete, send /proj/DIflow/di/eval/flow/tessent_example_hierarchical_flow_v2021.4/wrapped_cores/processor_core/5.generate_atpg_patterns/xmsim_36072.err to Cadence Support
发表于 2024-7-9 09:45:23 | 显示全部楼层
发表于 2024-7-9 10:16:36 | 显示全部楼层
thanks
 楼主| 发表于 2024-7-9 13:14:45 | 显示全部楼层
waves_0011 发表于 2024-7-9 09:45
关闭SELinux   https://bbs.eetop.cn/thread-967690-1-1.html
好了,多谢
发表于 2024-8-24 17:20:06 | 显示全部楼层
thanks, but is there other ways except disabling selinux
GMT+8, 2025-12-20 04:43 , Processed in 0.015140 second(s), 3 queries , Gzip On, Redis On.
