查看: 5585|回复: 30
[资料] Cadence RAK : Digital on Top (DoT) Mixed Signal Design Flow
发表于 2024-6-18 17:41:44 | 显示全部楼层 |阅读模式
Digital on Top (DoT) Mixed SignalDesign Flow Using Innovus Digital and Virtuoso Analog Platforms: RapidAdoption Kit (RAK)
There are two methodologies used for implementing Mixed Signal designs. Analog onTop (AOT) refers to the design flow where the top level of the design is represented asa schematic. In the AOT methodology, Virtuoso is typically the environment where theentire top level design is assembled. Digital on Top (DOT) refers to the design flowwhere the top level of the design is represented as a Verilog netlist. In the DOTmethodology, Innovus is typically the environment used for assembling the entire toplevel design. This tutorial is focused on the DoT flow with Innovus as the platform for thetop-level design.
电路档案
链接:https://pan.baidu.com/s/1dTILI6D4tbyQ7dgIRst9TQ
提取码:4hlx
DMS_Flow.pdf
3.42 MB, 下载次数: 446 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2024-6-18 18:38:29 | 显示全部楼层
谢谢!
发表于 2024-6-18 19:37:28 | 显示全部楼层
Thanks for sharing
发表于 2024-6-18 19:41:09 | 显示全部楼层
thanks a lot!
发表于 2024-6-18 19:57:28 | 显示全部楼层
thanks, very
发表于 2024-6-18 22:22:16 | 显示全部楼层
Thanks for sharing
发表于 2024-6-19 00:31:48 | 显示全部楼层
多谢分享
发表于 2024-6-19 08:40:51 | 显示全部楼层
多谢分享!
发表于 2024-6-19 08:42:23 | 显示全部楼层
感谢
发表于 2024-6-19 10:06:08 | 显示全部楼层
感谢分享,学习下。
GMT+8, 2025-9-16 09:10 , Processed in 0.018568 second(s), 4 queries , Gzip On, Redis On.
