查看: 2252|回复: 3
[求助] Monte carlo 仿真报错“Nominal simulation might have failed. ”
发表于 2024-6-4 17:06:01 | 显示全部楼层 |阅读模式
以下是报错内容:
ERROR (ADEXL-5069): Cannot complete the Monte Carlo simulation because of the following error for the test AD_035:AMP_0_test:1
Spectre simulator stopped due to following reasons:
Resolve these errors and rerun simulation.
在这个工艺的modle文件夹中有ReadmeMonteCarlo.txt文件,里面写了下面这句:To enable the gaussian distributed parameter set please select the section "3s" or "6s" of the file "param.scs"
and the section "mc_g" of the file xo035.scs in ADE's model library setup dialog box.
所以我的设置为
我没有勾选nominal,不知道为什么报错“Nominal simulation might have failed.
 楼主| 发表于 2024-6-4 18:56:23 | 显示全部楼层
取消勾选就可以了
 楼主| 发表于 2024-6-4 19:02:59 | 显示全部楼层
然后再仿报错
【新提醒】ADEXL工艺角仿真出错 - Analog/RF IC 设计讨论 - EETOP 创芯网论坛 (原名:电子顶级开发网) -
重复的modle要取消勾选(把绿框中的取消勾选)
发表于 2025-2-28 11:20:25 | 显示全部楼层
可能是ADE L勾选了除mc.lib以外的其他文件
GMT+8, 2025-12-26 07:27 , Processed in 0.063848 second(s), 4 queries , Gzip On, Redis On.
