楼主: tyouxu
Animate Preview 2024-10a-22.60
发表于 2025-5-10 10:32:05 | 显示全部楼层
感谢
发表于 2025-5-10 15:53:40 | 显示全部楼层
eow@meowu:/opt/Pulsic/animatepreview-2024-22b-22.60.p088.Patched/Patch/licenses$ su
Password:
[root@meowu licenses]# ./rlm
05/10 03:38 (rlm) RLM License Server Version 11.3BL1
        Copyright (C) 2006-2015, Reprise Software, Inc. All rights reserved.
05/10 03:38 (rlm) License server started on meowu
05/10 03:38 (rlm) Server architecture: x64_l1
05/10 03:38 (rlm) License files:
05/10 03:38 (rlm)     animatepreview.lic
05/10 03:38 (rlm)
05/10 03:38 (rlm) Web server starting on port 5054
05/10 03:38 (rlm) Using TCP/IP port 5053
05/10 03:38 (rlm) ... adding UDP/IP port 5053
05/10 03:38 (rlm) Starting ISV server pulsic on port 50662
05/10 03:38 (pulsic) RLM License Server Version 11.3BL1 for ISV "pulsic"
05/10 03:38 (pulsic) Settings from RLM Version 11.3BL1 for ISV "pulsic"
05/10 03:38 (pulsic) Server architecture: x64_l1
    RLM contains software developed by the OpenSSL Project
    for use in the OpenSSL Toolkit (http://www.openssl.org)
    Copyright (c) 1998-2008 The OpenSSL Project. All rights reserved.
    Copyright (c) 1995-1998 Eric Young (eay@cryptsoft.com) All rights reserved.
05/10 03:38 (pulsic) Server started on meowu (hostid: ANY) for:
05/10 03:38 (pulsic)         animate::rlmchecker animate::previewstart animate::previewversion
05/10 03:38 (pulsic)         animate::previewopen animate::previewoverride
05/10 03:38 (pulsic)         animate::previewplus animate::previewpreflow animate::previewpreconditions
05/10 03:38 (pulsic)         animate::previewpcelleval animate::previewplusavailable
05/10 03:38 (pulsic)         animate::previewcomplete animate::layoutsave animate::previewconstraints
05/10 03:38 (pulsic)         animate::previewcircuit animate::architect animate::previewcustomize
05/10 03:38 (pulsic)         animate::previewinterrupt animate::previewabort
05/10 03:38 (pulsic)         animate::previewempty animate::previewtoolarge
05/10 03:38 (pulsic)         animate::previewunsuitable animate::previewsave
05/10 03:38 (pulsic)         animate::previewedit
05/10 03:38 (pulsic) License files:
05/10 03:38 (pulsic)     animatepreview.lic
05/10 03:38 (pulsic) File descriptor limit increased from 1024 to 4096
您好,我按照大佬的文件步骤操作了,执行了rlm命令,日志是这样的,我也按照提示写了环境变量,但是我启动了virtuoso,里面还是没有Animate  Preview,请问您安装成功了吗?
发表于 2025-5-10 18:28:20 | 显示全部楼层
感谢
发表于 2025-5-11 23:24:15 | 显示全部楼层
感谢分享
发表于 2025-5-12 15:18:19 | 显示全部楼层
1111
发表于 2025-5-13 11:17:24 | 显示全部楼层
有安装方法吗
发表于 2025-5-13 14:29:55 | 显示全部楼层
Password:
[root ...
你在当前目录的.cdsinit文件里加入下面的语句再试一下?
; Animate Preview
load("/data1/eda/eda/cadence/AnimatePreview/animatepreview-2024-22b-22.60.p088.Patched/animatepreview/virtuosoplugin/animatepreview.ile")
要换成你对应的安装目录
发表于 2025-5-13 14:38:51 | 显示全部楼层
版图自动化
发表于 2025-5-13 15:35:57 | 显示全部楼层
Thanks
发表于 2025-5-14 21:27:22 | 显示全部楼层
谢谢
GMT+8, 2025-12-29 16:13 , Processed in 0.020036 second(s), 5 queries , Gzip On, Redis On.
