查看: 5768|回复: 14
新人使用scl_keygen添加S家feature问题求助
发表于 2024-5-22 11:36:05 | 显示全部楼层 |阅读模式
大家好,
我通过以下步骤尝试添加新feature(STAR-RC2_ULTRA_MANAGER)到license中(使用ocad自带的Synopsys.src):
1. 打开scl_keygen,填写HOST ID Daemon和HOST ID Feature为相同的Linux MAC地址
2. 填写HOST Name为Linux的”hostname“命令返回值
3. Port使用27000
4. 复制粘贴Synopsys.src中STAR-RC2_MANAGER的feature信息,并修改STAR-RC2_MANAGER为STAR-RC2_ULTRA_MANAGER
5. 点击Generate
6. 拖动生成的Synopsys.dat到fix.bat上
7. 添加snpslmd路径到Synopsys.dat第二行
7. 替换Linux中的Synopsys.dat
8. 重启lmg
环境:
CentOS 7.9
scl 2023.03(已使用1patch)
出现以下问题(Log):
05/21/2024 20:27:31 (snpslmd) INFO: Cloud detection enabled. 1
20:27:31 (snpslmd) SLOG: Summary LOG statistics is enabled.
20:27:31 (snpslmd) SLOG: FNPLS-INTERNAL-CKPT1
20:27:31 (snpslmd) SLOG: VM Status: 4
20:27:31 (snpslmd) SLOG: FNPLS-INTERNAL-CKPT5
20:27:31 (snpslmd) SLOG: TPM Status: 0
20:27:31 (snpslmd) SLOG: FNPLS-INTERNAL-CKPT6
20:27:31 (snpslmd) CVD License file has been Tampered.So no.of license Restricted to Original count
20:27:32 (snpslmd) Feature SSS is not enabled yet
20:27:32 (snpslmd) Feature 3D is not enabled yet
20:27:32 (snpslmd) Feature 3P is not enabled yet
20:27:32 (snpslmd) Feature 8alaxy-Zroute is not enabled yet
20:27:32 (snpslmd) Feature A3200DX is not enabled yet
20:27:32 (snpslmd) Feature A42MX is not enabled yet
20:27:32 (snpslmd) Feature A500K is not enabled yet
20:27:32 (snpslmd) Feature A54SX is not enabled yet
20:27:32 (snpslmd) Feature A54SXA is not enabled yet
20:27:32 (snpslmd) Feature A7 is not enabled yet
......(都是Feature XXX is not enabled yet)
20:27:32 (snpslmd) Feature FSSPICE is not enabled yet
20:27:32 (snpslmd) Feature FSPRO is not enabled yet
20:27:32 (snpslmd) Feature FSPRO2XSIM is not enabled yet
20:27:32 (snpslmd) License server system started on yian
20:27:32 (snpslmd) No features to serve, exiting
20:27:32 (snpslmd) EXITING DUE TO SIGNAL 36 Exit reason 4
20:27:32 (lmgrd) snpslmd exited with status 36 (No features to serve)
20:27:32 (lmgrd) snpslmd daemon found no features.  Please correct
20:27:32 (lmgrd) license file and re-start daemons.
20:27:32 (lmgrd)
20:27:32 (lmgrd) This may be due to the fact that you are using
20:27:32 (lmgrd) a different license file from the one you expect.
20:27:32 (lmgrd) Check to make sure that:
20:27:32 (lmgrd) /home/summer/Synopsys/scl/2023.03/admin/license/Synopsys.dat
20:27:32 (lmgrd) is the license file you want to use.
20:27:32 (lmgrd)
这下所有的Feature都没了。
有什么解决办法吗?谢谢!
发表于 2024-5-23 09:25:33 | 显示全部楼层
买正版
回复 支持 0 反对 1
发表于 2024-5-23 09:47:36 | 显示全部楼层
scl 2023 不能这样破解,找到已破解的,将snpslmd替换掉。
发表于 2024-5-23 15:02:22 | 显示全部楼层
发表于 2024-5-23 15:03:13 | 显示全部楼层
发表于 2024-5-23 15:27:06 | 显示全部楼层
步骤不对啊,第一步就应该修改src文件,把你要的feature加进去,再用工具生成dat文件,再用fix.bat添加SIGN信息,再修改第二行,最后启动
发表于 2024-5-23 20:19:55 | 显示全部楼层
thanks
发表于 2024-10-28 23:38:46 | 显示全部楼层
太牛了,是不是这样添加信息,很多S家license都能破解?
发表于 2025-1-2 16:46:34 | 显示全部楼层
ding
发表于 2025-2-4 17:34:45 | 显示全部楼层
xy19637 发表于 2024-5-23 15:27
步骤不对啊,第一步就应该修改src文件,把你要的feature加进去,再用工具生成dat文件,再用fix.bat添加SIGN ...
fix.dat 一运行就会把dat文件变成一个路径内容,怎么办呢?
GMT+8, 2025-10-8 03:34 , Processed in 0.018087 second(s), 3 queries , Gzip On, Redis On.
