查看: 1439|回复: 0
[求助] 哪位大佬可以帮忙下载APEC Paper,谢谢!
发表于 2024-5-19 14:26:20 | 显示全部楼层 |阅读模式
1,An Adaptive Current-Limit Soft Start Method for Asymmetric CLLC Resonant Converter
https://ieeexplore.ieee.org/document/10531640
2,https://ieeexplore.ieee.org/document/10529004
A 2.4-to-240W, 95.04% Peak Efficiency LLC Isolate Converter Controller with Symmetric Pulse-Width Balancing and Fixed-Period Hysteresis Burst Control
3,https://ieeexplore.ieee.org/document/10530396
Analysis of Oscillation Between Transformer Leakage Inductance and Schottky Diode Capacitance in DC-DC Converters
4,https://ieeexplore.ieee.org/document/10509148
Integrated Planar Magnetics Optimization for ∆ − ∆ LLC Converter with Wide Output Voltage Range
5,https://ieeexplore.ieee.org/document/10509334
A High Density 400 W DC/DC Power Module with Integrated Planar Transformer and Half Bridge GaN IC
6,https://ieeexplore.ieee.org/document/10509180
An Optimized Sensorless Synchronous Rectification Method for LLC Resonant Converter in Wide Output Voltage Range
7,https://ieeexplore.ieee.org/document/10509401
Small Signal Modelling of Hybrid Frequency and Phase-Shift Control Full-Bridge LLC Converter using Extended Describing Function Method
8,https://ieeexplore.ieee.org/document/10509453
A 2400 W/in3 1.8 V Bus Converter Enabling Vertical Power Delivery for Next-Generation Processors
9,https://ieeexplore.ieee.org/document/10509045
Common-Mode Noise Reduction in Full-Bridge LLC Resonant Converter with Split Primary Winding Transformer
10,https://ieeexplore.ieee.org/document/10509270
LLC Type Resonant Converter Adopting Peak Current Shaving with Third Harmonics Injection for Wide Output Voltage Range Application
11,https://ieeexplore.ieee.org/document/10509054
Next step in power MOSFET evolution boosts application efficiency
12,https://ieeexplore.ieee.org/document/10509128
A Variable Duty Cycle PFM Control Method for LLC Resonant Converter
13,https://ieeexplore.ieee.org/document/10509507
Modeling of secondary LLC resonant converter based on full frequency range extended describing function method
14,https://ieeexplore.ieee.
GMT+8, 2025-12-15 15:10 , Processed in 0.012032 second(s), 4 queries , Gzip On, Redis On.
