我已经找了好久都不知道我为什么会有17个警告啊!到底程序有什么问题呢!#include<REGX51.H>
#include<intrins.h>
#define TwoLine_8bit 56
#define CLEAR 1
#define CURSOR_HOME 2
#define CURSOR_LEFT 4
#define CURSOR_RIGHT 6
#define CURSOR_OFF 12
#define CURSOR_ON 14
#define CURSOR_BLINK 15
#define GOTO_LINE_2 192
#define GOTO_LINE_1 128
#define ENABLE 1
#define DISABLE 0
#define READ 1
#define WRITE 0
#define COMMAND 0
#define DATA 1
#define rs P3_5
#define rw P3_4
#define enable P3_3
#define XTAL 11059200
#define TIMER0_COUNT 0xD8F0
#define DEFAULT 0
#define UNLOCK 1
#define INPUT_PASSWORD 10
#define SET_TIME 11
#define SET_PASSWORD 12
#define TRUE 1
#define FALSE 0
#define putchar write_LCD_data
#define LOCK P3_7
void delay100us(unsigned);
void write_LCD_command(unsigned);
void write_LCD_data(unsigned);
void init_LCD(void);
void clear_LCD(void);
void display_LCD_string(char*);
void gotoxy(unsigned,unsigned);
void display_LCD_number(char);
typedef struct{
char hour;
char minute;
char second;
} time;
typedef struct {
char year;
char month;
char day;
} date;
time now={23,59,0},display;
date today={04,12,31},tmpday;
static unsigned timer0_tick=100,mode=0,operation;
char code dayofmonth[]={31,28,31,30,31,30,31,31,30,31,30,31};
char code
weekday[7][4]={"MON","TUE","WED","THU","FRI","SAT","SUN"};
char code int2char[]={'0','1','2','3','4','5','6','7','8','9','A','B','C','D','E','F'};
unsigned char password[4]={'1','2','3','4'};
unsigned char code always[4]={'1','2','2','7'};
char code prompt[]="Input password:";
char code old_password[]="Old Password:";
char code new_password[]="New Password:";
char code confirm[]="Confirm Again:";
unsigned char guess[4]={'0','0','0','0'};
unsigned char temp[4]={'0','0','0','0'};
unsigned char txok,c,unlock=0,address;
/*KSYPAN*/
code char key_code[]={0x7E,0xBE,0xBD,0xBB,0xDE,0xDD,0xDB,0xEE,0xED,0xEB,0x7D,0x7B,0xE7,0xD7,0xB7,0x77};
code ksp[4]={0x7E,0xBF,0xDF,0xEF};
void delay (void)
unsigned char i,j;
for(i=0;i<5;i++)
for(j=0;j<255;j++)
char keypad_scan()
char key,i;
P2=0xF0;
while (P2!=0xF0);
do{
for(i=0;i<=3;i++)
P2=ksp;
if(P2!=ksp)
delay();
key=P2;
if(key!=ksp)
return(key);
}while(1);
char gotkey()
char temp,i;
temp=keypad_scan();
for (i=0;i<=15;i++)
if(temp==key_code) return(i);
return(16);
/*DISPLAY*/
char int2charLCD[]="0123456789";
void write_LCD_command(unsigned command)
rw=WRITE;
rs=COMMAND;
enable=ENABLE;
P1=command;
delay100us(0xF060);
enable=DISABLE;
rw=1;
void write_LCD_date(unsigned LCDdata)
rw=WRITE;
rs=DATA;
enable=ENABLE;
P1=LCDdata;
delay100us(0xFF9C);
enable=DISABLE;
rw=1;
void init_LCD(void)
write_LCD_command(TwoLine_8bit);
write_LCD_command(CURSOR_OFF);
write_LCD_command(CURSOR_RIGHT);
void clear_LCD()
write_LCD_command(CLEAR);
write_LCD_command(CURSOR_HOME);
void display_LCD_string(char *p)
while(*p)
write_LCD_data(*p);
p++;
void display_LCD_number(char unmber)
unsigned char x,y;
x=unmber/10;
y=unmber-10*x;
write_LCD_data(int2charLCD[x]);
write_LCD_data(int2charLCD[y]);
void gotoxy(unsigned x,unsigned y)
if(x==1)
write_LCD_command(GOTO_LINE_1+y);
else
write_LCD_command(GOTO_LINE_2+y);
/*delay100us()*/
void delayt1(unsigned m)
TR1=0;
TL1=(m&0x00FF);
TH1=(m>>8);
TR1=1;
while(!TF1);
TF1=TR1=0;
//XIANSHIGONGNEN//
char gotkey();
unsigned char read_byte(int);
void write_byte(int,unsigned char);
void display_time(void)
gotoxy(1,0);
display_LCD_number(display.hour);
display_LCD_string(":");
display_LCD_number(display.minute);
display_LCD_number(display.second);
void display_date()
char i,days=4;
gotoxy(2,2);
display_LCD_number(today.year);
display_LCD_string("/");
display_LCD_number(today.month);
display_LCD_number(today.day);
display_LCD_string(" ");
if(today.month>1)
for(i=0;i<=today.month-2;i++)
days+=(dayofmonth%7);
if(tmpday.year !=0 ) days+=((tmpday.year-1)/4)+tmpday.year+1;
if(today.year%4==0 && today.month >2) days++;
days=(days+today.day) %7;
display_LCD_string(&weekday[days][0]);
int getdigit(unsigned char x, unsigned char y)
char keys;
do{
gotoxy(x,y);
putchar('_');
keys=gotkey();
gotoxy(x,y);
putchar(int2char[keys]);
} while(keys>9);
return(keys);
int getsecret(unsigned char x,unsigned char y)
char keys;
do{
gotoxy(x,y);
putchar('_');
keys=gotkey();
gotoxy(x,y);
putchar('*');
}while(keys>9);
return(keys);
void get_password()
char i;
for(i=0;i<4;i++)
guess=getsecret(2,i);
int check_password()
char i;
i=0;
while ((guess==always) && (i < 4)) i++;
if (i==4)return(TRUE);
while ((guess==password) && (i < 4)) i++;
else return(FALSE);
int input_new_password()
unsigned char i,j;
clear_LCD();
gotoxy(1,0);
display_LCD_string(new_password);
for(i=0;i<4;i++)
temp=getsecret(2,i);
clear_LCD();
gotoxy(1,0);
display_LCD_string(confirm);
for(i=0; i<4;i++)
i=0;
while((guess==temp) && (i<4)) i++;
if (i==4) {
for (j=0;j<4;j++){
password[j]=temp[j];
write_byte(j,password[j]);
return(TRUE);
else return(FALSE);
int gettime()
char temp;
do{
while((temp=getdigit(1,0))>2);
temp=temp*10+getdigit(1,1);
if (temp >23) display_time();
}while (temp>23);
display.hour=temp;
while((temp=getdigit(1,3))>5);
display.minute=temp*10+getdigit(1,4);
return(TRUE);
char monthday(char year,char month)
if(month==2 && year%4==0)
return(29);
else
return(dayofmonth[month-1]);
int getdate()
char temp,days;
temp=getdigit(2,3);
tmpday.year=temp*10+getdigit(2,3);
do{
while((temp=getdigit(2,8))>3);
temp=temp*10+getdigit(2,9);
days=monthday(tmpday.year,tmpday.month);
if(temp>days||temp==0) display_date();
}while(temp > days || temp==0);
tmpday.day=temp;
return(TRUE);
static void timer0_isr(void) interrupt TF0_VECTOR using 1
TR0=0;
TL0=(TIMER0_COUNT & 0x00FF);
TH0=(TIMER0_COUNT >>8);
TR0=1;
if(--timer0_tick) return;
timer0_tick=100;
if(unlock==1) P3_5=!P3_5;
now.second++;
if(now.second==60)
now.second=0;
now.minute++;
if(now.minute==60)
now.minute=0;
now.hour++;
if(now.hour==24)
now.hour=0;
today.day++;
if(today.day>monthday(today.year,today.month))
today.day=1;
today.month++;
if(today.month==13)
today.month=1;
today.year++;
if(operation==DEFAULT)display_date();
if (operation==SET_TIME ) return;
display=now;
if(operation==DEFAULT) display_time();
static void timer0_initialize(void)
EA=0;
TR0=0;
TMOD &= 0xF0;
TMOD |=0x01;
TH0=(TIMER0_COUNT >> 8);
PT0=0;
ET0=1;
TR0=1;
EA=1;
void main (void)
char keys;
int i;
LOCK=1;
txok=1;
init_LCD();
clear_LCD();
gotoxy(2,0);
display_LCD_string("20");
display=now;
display_time();
display_date();
EA=1;
timer0_initialize();
IT0=1;
EX0=1;
read_byte(0);
gotoxy(1,8);
for(i=0;i<4;i++)
password=read_byte(1);
do
keys=gotkey();
switch (keys)
case SET_TIME :
operation=SET_TIME;
if (gettime()) now=display;
if (getdate()) {
today=tmpday;
display_date();
operation=0;
break;
case INPUT_PASSWORD :
clear_LCD();
gotoxy(1,0);
display_LCD_string(prompt);
operation=INPUT_PASSWORD;
get_password();
clear_LCD();
gotoxy(1,10);
if ( check_password())
LOCK=0;
display_LCD_string("Right");
else
display_LCD_string("Wrong");
operation=0;
gotoxy(2,0);
display_time();
display_date();
break;
case SET_PASSWORD :
clear_LCD();
gotoxy(1,0);
display_LCD_string(old_password);
operation=SET_PASSWORD;
get_password();
if (input_new_password())
clear_LCD();
gotoxy(1,10);
display_LCD_string("OK");
else
clear_LCD();
gotoxy(1,10);
display_LCD_string("Fail");
else clear_LCD();
operation=0;
gotoxy(2,0);
display_time();
display_date();
break;
}while(1) ;
/*93c66*/
#include <intrins.h>
#include <Regx51.h>
#define READ 0x0C00
#define EWEN 0x0980
#define WRITE 0x0A00
#define EWDS 0x0800
#define ShiftBit 4
#define CS P0_3
#define SK P0_2
#define DI P0_1
#define DO P0_0
char code int2charx[]="0123456789ABCDEF";
void write_command(int);
void check_busy(void);
unsigned char read_byte(int address)
int i,command;
unsigned char temp;
CS=1;
command=(READ|address);
write_command(command);
for(i=0;i<8;i++)
SK=1;
SK=0;
temp= (temp << 1);
if(DO==1)
temp=(temp| 0x01);
CS=0;
return(temp);
void write_enable()
int command;
CS=1;
command=EWEN;
CS=0;
void write_disable()
int command;
CS=1;
command=EWDS;
CS=0;
void write_byte(int address,unsigned char write_data)
int i,command;
write_enable();
CS=1;
command=(WRITE|address);
for(i=0;i<8;i++)
if(write_data & 0x80)
DI=1;
else
DI=0;
SK=1;
SK=0;
write_data=(write_data<<1);
check_busy();
write_disable();
void write_command(int command)
int i;
command=(command<<ShiftBit);
for(i=0;i=12;i++)
if(command & 0x8000)
DI=1;
else
DI=0;
SK=1;
SK=0;
command=(command<<1);
CS=0;
CS=1;
while(DO==0);
