查看: 1740|回复: 3
[求助] 华大九天报错dc analysis is omitted because no dc-outputs are specified.
发表于 2024-5-13 14:43:46 | 显示全部楼层 |阅读模式
悬赏20资产已解决
在华大九天运行前仿的时候报错显示:
Warning: Total 2 dangling nodes are removed.
Warning: Dangling node `net2' is removed.
Warning: Dangling node `net1' is removed.
Warning: Dangling device `vv2' is removed.
Warning: Dangling device `vv0' is removed.
Warning: Total 2 dangling devices are removed.
Warning: No dc path to ground from node `drain'.
Warning: No dc path to ground from node `gate'.
Warning: No dc path to ground from va device `xm0' inner net a1.
Warning: [/home/ZZH/simulation/ZZH/4mv2_test_schematic_ALPS/4mv2_test_schematic.netlist:21]: Only one connection to node `net0' from this line.
Warning: [/home/ZZH/simulation/ZZH/4mv2_test_schematic_ALPS/4mv2_test_schematic.netlist:19]: Only one connection to node `source' from this line.
Error:  dc analysis is omitted because no dc-outputs are specified
这是hspice网表
*test
* Type     : hspice
* Tool     : AETHER-SE
* Date     : Mon May 13 14:28:57 2024
* User     : ZZH
* Top Design : 4mv2/test/schematic
.hdl   "/homes/ZZH/huadajiutian/4mv2/MoS2FET/veriloga/veriloga.va"
.GLOBAL
* Library : 4mv2
* Cell    : test
* View    : schematic
**TopDesStart
XM0 drain gate source MoS2FET lambda = 0 sigma = 0.006
VV0 net1 0 DC 0
VV1 net0 0 DC A
VV2 net2 0 DC 3
**TopDesEnd
各位兄弟有知道为什么的吗?
最佳答案
查看完整内容
你这网表是手写的?MM1 d g s buck model w l 你的后面几个都没有 用电路编辑器生成哈 XM0 net1 net0 net2 net1 MoS2FET W=10u L=0.5u
发表于 2024-5-13 14:43:47 | 显示全部楼层
 楼主| 发表于 2024-5-14 15:34:15 | 显示全部楼层
chuchuang 发表于 2024-5-14 10:20
你这网表是手写的?MM1 d g s buck model w l   你的后面几个都没有 用电路编辑器生成哈 XM0 net1 net0 net ...
兄弟,警告确实没有再报错了,但是他却显示我的这个mos的模型卡找不到了,这个mos是我拿veriloga生成的器件,然后改了下阈值电压生成的symbol,但是现在找不到这个模型了
发表于 2025-10-19 20:51:28 | 显示全部楼层
怎么解决的请问
GMT+8, 2025-10-30 10:53 , Processed in 0.025324 second(s), 4 queries , Gzip On, Redis On.
