查看: 16114|回复: 62
synopsys2023版本lic激活失败
发表于 2024-5-11 10:08:33 | 显示全部楼层 |阅读模式
哈喽大家好,最近公司服务器环境安装了synopsys2023版本的软件,使用工具生成的lic文件,修改了前两行,可以运行起来,但是启动lic之后看日志感觉没启动,这个有大佬帮忙看看是哪里的问题不。
lic前两行
SERVER nis01 005056ADFC75 27000
DAEMON snpslmd /etc/license/bin/2018.06-SP1/linux64/bin/snpslmd
启动lic命令
/etc/license/bin/2018.06-SP1/linux64/bin/lmgrd -c /etc/license/license_venus_2019.dat -l /etc/license/synopsys2023.log
启动之后查看log
17:47:58 (snpslmd) License server system started on nis01
17:47:58 (snpslmd) No features to serve, exiting
17:47:58 (snpslmd) EXITING DUE TO SIGNAL 36 Exit reason 4
17:47:58 (lmgrd) snpslmd exited with status 36 (No features to serve)
17:47:58 (lmgrd) snpslmd daemon found no features.  Please correct
17:47:58 (lmgrd) license file and re-start daemons.
17:47:58 (lmgrd)
17:47:58 (lmgrd) This may be due to the fact that you are using
17:47:58 (lmgrd) a different license file from the one you expect.
17:47:58 (lmgrd) Check to make sure that:
17:47:58 (lmgrd) /etc/license/license_venus_2019.dat
17:47:58 (lmgrd) is the license file you want to use.
然后启动的时候提示错误如下:
[SCL] SCL trace is enabled.
DB Create table failed: table TRACE_INFO already exists
FlexNet Licensing checkout error: The desired vendor daemon is down.
Check the lmgrd log file, or try lmreread.
Feature:       Verdi
Vendor:Host:   nis01
License path:  27000@nis01:
FlexNet Licensing error:-97,121
license file(s):  27000@nis01
[SCL] 05/11/2024 01:18:34 PID:36240 Client:lsf-node4 Checkout denied Verdi 2023.12
*WARN* Verdi-Elite (Verdi) license is not available. Try to check out Verdi-Apex (Verdi-Ultra) license.
Feature:       VERDI-ULTRA
Vendor:Host:   nis01
[SCL] 05/11/2024 01:18:34 PID:36240 Client:lsf-node4 Checkout denied VERDI-ULTRA 2023.12
[ERROR] Could not checkout Verdi Elite (Verdi) license. Use verdi -licdebug for more information.
发表于 2024-5-11 12:45:07 | 显示全部楼层
you should try scl2023
发表于 2024-5-11 13:44:06 | 显示全部楼层
2023版本就不要用2020以前的scl了,至少要2021.03  license都变了有SIGN=的关键词
发表于 2024-5-11 14:03:42 | 显示全部楼层
您好,[SCL] 05/11/2024 01:18:34 PID:36240 Client:lsf-node4 Checkout denied Verdi 2023.12 这一行最后的 Verdi 2023.12 可以分享一下吗?
 楼主| 发表于 2024-5-11 14:14:56 | 显示全部楼层
DAEMON snpslmd /App/synopsys/scl/2023.03-SP1/linux64/bin/snpslmd
还有启动破解lic的命令也改了这个路径,然后在不开启verdi下的log是下面这个
14:10:23 (lmgrd) License file(s): /etc/license/Synosys_00620B3390A0.dat
14:10:23 (lmgrd) lmgrd tcp-port 27000
14:10:23 (lmgrd) (@lmgrd-SLOG@) ===============================================
14:10:23 (lmgrd) (@lmgrd-SLOG@) === LMGRD ===
14:10:23 (lmgrd) (@lmgrd-SLOG@) Start-Date: Sat May 11 2024 14:10:23 CST
14:10:23 (lmgrd) (@lmgrd-SLOG@) PID: 940
14:10:23 (lmgrd) (@lmgrd-SLOG@) LMGRD Version: v11.16.4.0 build 252457 x64_lsb ( build 252457 (ipv6))
14:10:23 (lmgrd) (@lmgrd-SLOG@) === Network Info ===
14:10:23 (lmgrd) (@lmgrd-SLOG@) Listening port: 27000
14:10:23 (lmgrd) (@lmgrd-SLOG@) === Startup Info ===
14:10:23 (lmgrd) (@lmgrd-SLOG@) Server Configuration: Single Server
14:10:23 (lmgrd) (@lmgrd-SLOG@) Command-line options used at LS startup: -c /etc/license/Synosys_00620B3390A0.dat -l /etc/license/synopsys2023.log
14:10:23 (lmgrd) (@lmgrd-SLOG@) License file(s) used:  /etc/license/Synosys_00620B3390A0.dat
14:10:23 (lmgrd) Starting vendor daemons ...
14:10:23 (lmgrd) Started snpslmd (internet tcp_port 33672 pid 942)
14:10:23 (snpslmd) FlexNet Licensing version v11.19.1.0 build 285581 x64_lsb
14:10:23 (snpslmd) lmgrd version 11.16, snpslmd version 11.19
05/11/2024 14:10:26 (snpslmd) INFO: Pooling on VENDOR_STRING is Disabled (to enable, set SCL_POOL_VS=1)
05/11/2024 14:10:26 (snpslmd) Synopsys Corporate Licensing (SCL) Release: version SCL_2023.03_SP1
05/11/2024 14:10:42 (snpslmd) INFO: License sanity check enabled (3600)
05/11/2024 14:10:42 (snpslmd) INFO: File descriptor limit (soft, hard) for snpslmd: 1024000, 1024000
05/11/2024 14:10:42 (snpslmd) INFO: TCP - tcp_keepalive_time - 7200 | tcp_keepalive_intvl - 75 | tcp_keepalive_probes - 9 | tcp_fin_timeout - 60 | net.ipv4.tcp_max_syn_backlog=2048 | net.core.somaxconn=128
05/11/2024 14:10:42 (snpslmd) INFO: Cloud detection enabled. 1
14:10:42 (snpslmd) SLOG: Summary LOG statistics is enabled.
14:10:42 (snpslmd) SLOG: FNPLS-INTERNAL-CKPT1
14:10:42 (snpslmd) SLOG: VM Status: 4
14:10:42 (snpslmd) SLOG: FNPLS-INTERNAL-CKPT5
14:10:42 (snpslmd) SLOG: TPM Status: 0
14:10:42 (snpslmd) SLOG: FNPLS-INTERNAL-CKPT6
14:10:42 (snpslmd) CVD License file has been Tampered.So no.of license Restricted to Original count
发表于 2024-5-11 15:21:45 | 显示全部楼层
verdi2023分享一下,我给你说怎么搞
发表于 2024-5-11 15:24:11 | 显示全部楼层
lic要重新做,lic要增加SIGN字段
 楼主| 发表于 2024-5-11 16:41:33 | 显示全部楼层
我是直接用这个工具搞的,咋增加 字段
 楼主| 发表于 2024-5-11 16:49:22 | 显示全部楼层
朋友给我了个带SIGN的就可以用,但是我不知道咋生成,我两个工具生成的都没这个字段=,=
发表于 2024-5-11 16:57:19 | 显示全部楼层
要用fix.dat去加上去
站长推荐 上一条 /3 下一条
GMT+8, 2025-9-10 16:21 , Processed in 0.024156 second(s), 3 queries , Gzip On, Redis On.
