查看: 2384|回复: 2
Tanner 2019 License问题
发表于 2024-4-27 15:21:50 | 显示全部楼层 |阅读模式
大神们求助,我已经放入了license.txt,而且路径已经修改了好,软件启动还是有如下error
The following FlexNet errors were found:
    Server C:\MentorGraphics\License_Files\license.txt: Invalid (inconsistent) license key.
The license key and data for the feature do not match.
This usually happens when a license file has been altered.
Feature:       mentorall_s
License path:  C:\MentorGraphics\License_Files\license.txt;
FlexNet Licensing error:-8,523
Feature:       mgc_s
    Server C:\flexlm\license.dat: Cannot find license file.
The license files (or license server system network addresses) attempted are
listed below.  Use LM_LICENSE_FILE to use a different license file,
or contact your software provider for a license file.
Feature:       edsledit
License path:  C:\flexlm\license.dat;
FlexNet Licensing error:-1,234
 楼主| 发表于 2024-5-7 15:46:05 | 显示全部楼层
求助大神
发表于 2024-9-9 18:17:26 来自手机 | 显示全部楼层
很简单,按照报错提示,更改你的license后缀名为.dat而不是.txt。相应的更改你的环境变量值的改文件名。最后c盘创建flexlm文件夹,放入该后缀的license.dat文件即可。
GMT+8, 2025-12-26 02:45 , Processed in 0.014336 second(s), 3 queries , Gzip On, Redis On.
