查看: 1351|回复: 1
[求助] Cadence DFT: modus atpg smartscan遇到如下问题求助
发表于 2024-4-22 13:56:41 | 显示全部楼层 |阅读模式
smartscan modus atpg的时候遇到如下问题:
WARNING (TLS-027): [Severe] The pin serlalizer_scan_enable is at value 'x' for block COMPACTOR.smartscan_clock_controller_inst,  after simulating a pulse at the top level clock pin.lend [TLS_027]
发表于 2024-4-24 03:04:44 | 显示全部楼层
如果已经产生了pattern,simulation看一下
GMT+8, 2025-12-18 17:56 , Processed in 0.040011 second(s), 4 queries , Gzip On, Redis On.
