查看: 1373|回复: 2
[求助] 关于simc 018工艺 qrc提取寄生参数的问题。av_extracted 为0
发表于 2024-3-29 18:17:50 | 显示全部楼层 |阅读模式
悬赏200资产未解决
当我采用ET 191版本时,av_extracted  为0  log文件中没有error,extview.tmp 也是存在的。但是av_extracted  为0   请问如何解决?
当我采用ET 152版本时,报错:ERROR (LBRCXM-644): Bad return status from RCX script generator. 0x8b  ,xtview.tmp 不存在的,请问如何解决?
综上 如何解决?
INFO (CAPGEN-41199):
Techgen -trans results will be written to directory: /work/project1/pdk_pre_estimate/qrc_test/haoyu/LVS/inv1_x2_clk/query_output/Design
INFO (CAPGEN-41737): Lvs layers M0poly are not mapped in layer_setup file
te,D,G,S -genericMos p18_hvbn_40v_7t_gate,D,G,S -genericMos n18_esd_hvbn_6v_6t_gate,D,G,S -genericMos n18_esd_hvbn_12v_6t_gate,D,G,S -genericMos n18_esd_hvbn_30v_6t_gate,D,G,S -genericMos n18_esd_hvbn_40v_6t_gate,D,G,S -genericMos p18_esd_hvbn_6v_7t_gate,D,G,S -genericMos p18_esd_hvbn_12v_7t_gate,D,G,S -genericMos p18_esd_hvbn_30v_7t_gate,D,G,S -genericMos p18_esd_hvbn_40v_7t_gate,D,G,S -genericMos n18_sab_hvbn_6v_6t_gate,D,G,S -genericMos n18_sab_hvbn_12v_6t_gate,D,G,S -genericMos n18_sab_hvbn_30v_6t_gate,D,G,S -genericMos n18_sab_hvbn_40v_6t_gate,D,G,S -genericMos p18_sab_hvbn_6v_7t_gate,D,G,S -genericMos p18_sab_hvbn_12v_7t_gate,D,G,S -genericMos p18_sab_hvbn_30v_7t_gate,D,G,S -genericMos p18_sab_hvbn_40v_7t_gate,D,G,S -genericMos n50_sab_hvbn_6v_6t_gate,D,G,S -genericMos n50_sab_hvbn_12v_6t_gate,D,G,S -genericMos n50_sab_hvbn_30v_6t_gate,D,G,S -genericMos n50_sab_hvbn_40v_6t_gate,D,G,S -genericMos p50_sab_hvbn_6v_7t_gate,D,G,S -genericMos p50_sab_hvbn_12v_7t_gate,D,G,S -genericMos p50_sab_hvbn_30v_7t_gate,D,G,S -genericMos p50_sab_hvbn_40v_7t_gate,D,G,S -genericMos nt18_hvbn_6v_gate,D,G,S -genericMos nt18_hvbn_12v_gate,D,G,S -genericMos nt18_hvbn_30v_gate,D,G,S -genericMos nt18_hvbn_40v_gate,D,G,S -genericMos nt50_hvbn_6v_gate,D,G,S -genericMos nt50_hvbn_12v_gate,D,G,S -genericMos nt50_hvbn_30v_gate,D,G,S -genericMos nt50_hvbn_40v_gate,D,G,S -genericMos p18_hvbn_dpw_6v_7t_gate,D,G,S -genericMos p18_hvbn_dpw_12v_7t_gate,D,G,S -genericMos p18_hvbn_dpw_30v_7t_gate,D,G,S -genericMos p18_hvbn_dpw_40v_7t_gate,D,G,S -genericMos p50_hvbn_dpw_6v_7t_gate,D,G,S -genericMos p50_hvbn_dpw_12v_7t_gate,D,G,S -genericMos p50_hvbn_dpw_30v_7t_gate,D,G,S -genericMos p50_hvbn_dpw_40v_7t_gate,D,G,S -genericMos nld35g5_rox_gs_seed,D,G,S -genericMos nld40g5_rox_gs_seed,D,G,S -genericMos nde20g5_gs_iso_hvbn_seed,D,G,S -genericMos nde30g5_gs_iso_hvbn_seed,D,G,S /work/project1/pdk_pre_estimate/qrc_test/haoyu/LVS/inv1_x2_clk/query_output/Design
INFO (LBRCXM-709): *****  Quantus QRC terminated abnormally  *****
发表于 2024-6-13 18:52:40 来自手机 | 显示全部楼层
楼主我也遇到了相同问题
发表于 2024-9-29 16:59:15 | 显示全部楼层
请问解决了吗?我这边碰到文件大小为0,IT那边说的是没有licence,配置后就正常了
GMT+8, 2025-9-13 08:34 , Processed in 0.013856 second(s), 3 queries , Gzip On, Redis On.
