查看: 2030|回复: 9
【求助】orbitIO22相关feature
发表于 2024-3-24 11:21:56 | 显示全部楼层 |阅读模式
   有大佬有适用于OrbitIO22的feature “OrbitIO_Sys_PlanC ”
 楼主| 发表于 2024-3-25 10:44:11 | 显示全部楼层
顶一下
发表于 2024-3-25 14:01:12 | 显示全部楼层
You can use this file crack your OrbitIO.
1. Please download orbitio-crack.jar and put it to your OrbitIO or IntegrityPlanner root folder.
2. Open your launcher file and edit it
  1. ::
  2. :: Run the virtual machine.
  3. ::
  4. !JAVA! -cp %CP% !JVMARGS_FILE! !JVMARGS! !CMD_JVMARGS! -javaagent:%HOMEDIR%\orbitio-crack.jar %*
  5. set EXIT=%errorlevel%
    复制代码
orbitio-crack.zip
226.18 KB, 下载次数: 38 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2024-3-26 21:57:52 | 显示全部楼层
1. Please download orbitio-crack.jar and put it to your ...
In Linux, I copied your code into my launcher file and started OrbitIO, but I got the following error. Do you know why?
发表于 2024-3-27 08:13:02 | 显示全部楼层
zhengcaiping 发表于 2024-3-26 21:57
In Linux, I copied your code into my launcher file and started OrbitIO, but I got the following er ...
You need edit it when you add it to your launcher shell file.
For linux shell file:
  1. -javaagent: $HOMEDIR/orbitio-crack.jar
    复制代码
发表于 2024-3-27 08:50:37 | 显示全部楼层
看起来像jar 放的路径不对  按大佬要求位置放
 楼主| 发表于 2024-3-27 17:39:05 | 显示全部楼层
  Thanks!!!
发表于 2024-4-4 05:14:27 | 显示全部楼层
interesting
发表于 2024-4-4 05:15:38 | 显示全部楼层
thank you
发表于 2024-5-31 08:23:49 | 显示全部楼层
GMT+8, 2025-12-23 09:56 , Processed in 0.094957 second(s), 4 queries , Gzip On, Redis On.
