查看: 4094|回复: 15
求mentor的lnx版的最新flelm管理工具SALT,谢谢
发表于 2024-3-4 20:04:36 | 显示全部楼层 |阅读模式
发表于 2024-3-5 21:27:39 | 显示全部楼层
qiu!!!!!!!!
发表于 2024-3-5 21:56:50 | 显示全部楼层
thanks for sharing
发表于 2024-3-5 22:10:12 | 显示全部楼层
SiemensLicenseServer_v2.4.0.0_Lnx64_x86-64.part1.rar (31 MB , 下载次数: 117 )
SiemensLicenseServer_v2.4.0.0_Lnx64_x86-64.part2.rar (31 MB , 下载次数: 114 )
SiemensLicenseServer_v2.4.0.0_Lnx64_x86-64.part3.rar (14.02 MB , 下载次数: 116 )
SiemensLicenseServer_v2.4.0.0_Win64_x86-64.part1.rar (31 MB , 下载次数: 88 )
SiemensLicenseServer_v2.4.0.0_Win64_x86-64.part2.rar (31 MB , 下载次数: 85 )
SiemensLicenseServer_v2.4.0.0_Win64_x86-64.part3.rar (31 MB , 下载次数: 93 )
SiemensLicenseServer_v2.4.0.0_Win64_x86-64.part4.rar (29.65 MB , 下载次数: 91 )
发表于 2024-3-5 22:26:53 | 显示全部楼层
Thank you for the sharing.
发表于 2024-3-6 00:42:11 | 显示全部楼层
发表于 2024-3-6 03:27:00 | 显示全部楼层
发表于 2024-3-6 08:32:26 | 显示全部楼层
SALT is a new Siemens licensing solution based on FlexNet licensing technology. SALT 1.4.3
requires FLEXnet license server running at version 11.16.4.0 or higher. If you use server-
based licenses, you will need to update the license server accordingly.
If you are currently using the environment variable MGLS_LICENSE_FILE then you need to
set a new environment variable SALT_LICENSE_SERVER with the same value.
MGLS_LICENSE_FILE can remain set to support older versions
Installation Process (Part 1)
https://www.youtube.com/watch?v=3-usuZ7DF0k
Installation Process (Part 2)
https://www.youtube.com/watch?v=z9JY2c41Vuc
发表于 2024-3-7 01:35:19 | 显示全部楼层
感謝分享~~~~
发表于 2024-3-7 03:35:42 | 显示全部楼层
requires  ...
thanks
GMT+8, 2025-12-21 03:45 , Processed in 0.033357 second(s), 4 queries , Gzip On, Redis On.
