查看: 1062|回复: 1
[求助] liberate 报错 LIB-11
发表于 2024-2-29 15:15:13 | 显示全部楼层 |阅读模式
请教一下各位大佬,在k standard cell的时候经常中途报错下面的错,求教一下如何解决啊?
warning(LIB-11):cannot remove non-empty temporary 。it is possible that your extranl simulation run had errors or failed or your NSF file system is extremely slow
补充内容 (2024-2-29 15:15):
另外还报了。liberate:  /grid/cic/vfic_cm/ws/ALTOS.........../ccsn.css.5461:void arcChar:: updataValsIndices(..........) failed
发表于 2024-7-22 11:28:51 | 显示全部楼层
您解决了吗?我也遇到这个问题
GMT+8, 2025-12-18 07:39 , Processed in 0.012173 second(s), 3 queries , Gzip On, Redis On.
