楼主: ardenmann20
Debussy 54v9-Win32 with crack 下载
发表于 2009-1-24 11:16:34 | 显示全部楼层
可以下載, 但是 part1 的 RAR 檔案是壞的!!
发表于 2009-1-25 13:41:29 | 显示全部楼层
好东西,正在找呢,谢谢楼主的分享
发表于 2009-2-2 13:31:21 | 显示全部楼层
感謝分享, 正在找這套tool...
发表于 2009-2-3 11:54:19 | 显示全部楼层
谢谢了,好东西
发表于 2009-2-6 20:39:34 | 显示全部楼层
Thanks a lot!
发表于 2009-2-7 14:22:03 | 显示全部楼层
Thank you very much
发表于 2009-2-11 20:22:36 | 显示全部楼层
下载了好东西,只好回帖了
发表于 2009-2-14 07:08:20 | 显示全部楼层
How to integrate debussy with modelsim or questasim
 楼主| 发表于 2009-2-15 00:43:51 | 显示全部楼层
How to use FSDB under Modelsim
1.        Edit X:\modelsim\modelsim.ini
Veriuser = Full_path_of_novas.dll
Full_path_of_novas.dll may look like c:\novas\debussy\share\pli\modelsim_pli54\winnt\novas.dll
If the above setting doesn’t work, you must set PLIOBJS.
2.        Set the " PLIOBJS"
system environment variable
before running vsim.
PLIOBJS= C:\Novas\Debussy\share\PLI\modelsim_pli54\WINNT\novas.dll
3.        In your testbench, add the following text:
initial
   begin
      $fsdbDumpfile("filename_you_want.fsdb");
      $fsdbDumpvars;
   end
发表于 2009-2-17 22:46:37 | 显示全部楼层
debussy 54v9-nt下载
多谢多谢,看看
GMT+8, 2025-12-14 18:42 , Processed in 0.019328 second(s), 5 queries , Gzip On, Redis On.
