楼主: chaochao3
scl patch
发表于 2024-7-10 22:18:43 | 显示全部楼层
使用谢谢
发表于 2024-11-1 21:11:32 | 显示全部楼层
Thank you!!
发表于 2024-11-2 05:30:59 | 显示全部楼层
What are the differences with MonoSlayer?
The only difference between the previously distributed MonoSlayer and the sclp file is the file size, while the version information remains the same, as shown below:
Synopsys Universal License Patcher v1.1 Build0410 (TeamEFA)
[v1.1] Update large file support
Is this used for patching the license daemon? Is it also capable of patching applications?
However, this does not work in the 2024.09 release. Specifically, it works in hspice 24.09 but throws an error.
Is this valid for versions including and after 2024.09?
发表于 2024-11-4 08:49:29 | 显示全部楼层
感谢分享
发表于 2024-11-4 12:59:28 | 显示全部楼层
thanks
发表于 2024-11-6 19:28:55 | 显示全部楼层
楼主楼主,这个最高支持哪个版本的哇~~~
发表于 2024-11-8 03:17:51 | 显示全部楼层
同好奇支持啥版本,下来试试看看
发表于 2024-11-22 08:49:55 | 显示全部楼层
大佬,最高支持到多高版本的scl哇
发表于 2024-11-22 22:51:25 | 显示全部楼层
thank you boss
发表于 2025-2-18 14:59:00 | 显示全部楼层
看看能不能解决问题,lic问题搞好久了
GMT+8, 2025-10-18 17:29 , Processed in 0.021941 second(s), 3 queries , Gzip On, Redis On.
