查看: 1543|回复: 2
[求助] 使用vcs进行PA仿真时出错【XMRE】
发表于 2023-12-28 15:59:26 | 显示全部楼层 |阅读模式
悬赏36资产未解决
错误内容如下:
Error-[XMRE] Cross-module reference resolution error
/ic/eda_tools/synopsys/vcs_vP-2019.06-SP1_P/etc/upf/upf_package.svlp, 1
  Error found while trying to resolve cross-module reference.
  token 'back'.  Originating module 'PowerScope', first module hit
  'PowerNetworkModel'.
  Source info: assign pd_trng_group_domain_states[0] =
  (PowerNetworkModel.ps_hmd_top.pd_trng.primary.supply_set_state[1] &
  PowerNetworkModel.ps_hmd_top.pd_trng.back.supply_set_state[0]);
  Instance stack trace:
      PowerScope
      PowerNetworkModel
  /ic/eda_tools/synopsys/vcs_vP-2019.06-SP1_P/etc/upf/upf_components.svlp, 907
我理解是因为UPF里面写了这样的约束:
add_power_state -domain pd_trng \
-state normal \
        {-logic_expr {pd_trng.primary == ON && pd_trng.back == ON}} \
-state shutoff \
        {-logic_expr {pd_trng.primary == OFF && pd_trng.back == ON}}
一个domain的状态由两个supply set的状态决定,这样写upf不是很正常吗,为什么PA仿真时会报错呢
发表于 2024-1-2 12:29:17 | 显示全部楼层
没有.back这样的supply set handle吧
 楼主| 发表于 2024-1-2 14:49:16 | 显示全部楼层
可以自定义吧,这个确实是我自定义的一个handle,后来我不用.back了,直接用那个具体的supply set名称搞定了
GMT+8, 2025-9-16 03:27 , Processed in 0.015875 second(s), 4 queries , Gzip On, Redis On.
