查看: 1734|回复: 0
[求助] uvm_re_match这个正则匹配到底是怎么正则呢,匹配到一部分字符串,算成功匹配了么
发表于 2023-12-27 19:58:33 | 显示全部楼层 |阅读模式
UVM_ERROR   svt_axi_base_master_common.svp(3231)  @877808.000000ns: uvm_test_top.env.axi_system_env.master[1]  [check exclusive write_transactions] {OBJECT_NUM('d10000) PORT_ID('di) PORT_NAME() TYPE(WRITE)  COHERENT_XACT_TYPE(DVMMESSAGE) ID('h32e) SECURE( 'd1) ADDR('h2e0) CACHE_TYPE('d0) EXCL_START_TIME(877770.0000000 ns)} Response Mismatch!! Expected [SLVERR] but Actual [EXOKAY]
像这种message,使用uvm_re_match("Response Mismatch!! Expected [SLVERR] but Actual [EXOKAY]", msg) ,好像干不掉。
大神帮忙看看。谢谢
GMT+8, 2025-12-28 16:13 , Processed in 0.326317 second(s), 4 queries , Gzip On, Redis On.
