查看: 2045|回复: 5
[原创] Help to download VLSI paper 2023
发表于 2023-12-25 10:35:58 | 显示全部楼层 |阅读模式
https://ieeexplore.ieee.org/document/10278146
Behavioral Model for High-Speed SAR ADCs With On-Chip References
2
https://ieeexplore.ieee.org/document/10286528
A 1-GS/s 12-bit Single-Channel Pipelined ADC in 28-nm CMOS With Input-Split Fully Differential Ring Amplifier
3
https://ieeexplore.ieee.org/document/10258404
A Current-Adjusting Auto-Zeroing Technique for DC-Offset and Flicker-Noise Cancellation
4
https://ieeexplore.ieee.org/document/10296839
A 55-nm Three-Stage Operational Transconductance Amplifier With Single Cascode Miller Compensation for Large Capacitive Loads
Thanks a lot,
 楼主| 发表于 2023-12-26 10:30:44 | 显示全部楼层
please help !
 楼主| 发表于 2023-12-28 13:16:51 | 显示全部楼层
please help
发表于 2023-12-29 19:50:24 | 显示全部楼层
 楼主| 发表于 2023-12-29 20:57:30 | 显示全部楼层
#4
What I need is  is VLSI transaction 2023 not symposium 2023
the download address has attached .
发表于 2024-10-1 21:44:10 | 显示全部楼层
kan kan
GMT+8, 2025-12-20 05:21 , Processed in 0.015626 second(s), 3 queries , Gzip On, Redis On.
