查看: 2399|回复: 5
[求助] 用innovus做带scan chain设计placement时遇到的问题
发表于 2023-12-20 16:25:19 | 显示全部楼层 |阅读模式
在innovus中做place时设置了place_gloabl_ignore_scan false和place_global_reorder_scan false,但是执行place_opt_design时报错了:
ERROR:Scan chains exist in this design but are not defined for 0.00% flops. Placement and timing QoR can be severely impacted in this case! It is highly recommend to keep place_gloabl_ignore_scan option as its default value "true" with scan chains definition.
虽然报错了但是place和scan reorder都做了。如果将place_gloabl_ignore_scan设置成true则不会报错。请问各位大佬正确的流程应该怎么做的,以及为什么出现这个问题?
发表于 2023-12-20 16:57:00 | 显示全部楼层
 楼主| 发表于 2023-12-20 19:28:28 | 显示全部楼层
maomao198477 发表于 2023-12-20 16:57
It is highly recommend to keep place_gloabl_ignore_scan option as its default value "true" with scan ...
但是我在别人的flow的里看到有scan chain的时候是把这个设成false的,请问这个设置成true和false有什么讲究吗
发表于 2023-12-21 10:49:38 | 显示全部楼层
scan def读了吗,scan def和网表匹配吗
 楼主| 发表于 2023-12-22 14:26:07 | 显示全部楼层
读了,匹配的
发表于 2023-12-26 14:09:14 | 显示全部楼层
这句话,Scan chains exist in this design but are not defined for 0.00% flops
#4 F方向是对的,好好检查下scandef和netlist匹配问题,或者report一下scan chain正确进来了没
GMT+8, 2025-12-19 15:26 , Processed in 0.023981 second(s), 5 queries , Gzip On, Redis On.
