查看: 1599|回复: 2
[求助] 请问这个notifier为啥时x态,这样正常吗?
发表于 2023-12-12 17:04:17 | 显示全部楼层 |阅读模式
新人跑后仿没发现问题,但是老板找到个x态,不知道为啥会这样
工艺库里该模块代码如下
module DRQHDV0 (D, RD, CK, Q);
  input D, RD, CK;
  output Q;
  reg NOTIFIER;
  supply1 xSN;
wire ENABLE_D;
  not   XX0 (xRN,RD);
  buf     IC (clk,CK);
  udp_dff I0 (n0,D, clk, xRN, xSN, NOTIFIER);
  buf     I1 (Q, n0);
  assign ENABLE_D= (D) ? 1'b1:1'b0;
  `ifdef functional // functional //
  `else // functional //
    not SMC_I5(ENABLE_NOT_RD,RD);
  specify
        // arc CK --> Q
        (posedge CK => (Q : D))  = (1.0,1.0);
        if(CK==1'b0 && D==1'b0)
        // arc RD --> Q
        (posedge RD => (Q : 1'b0))  = (1.0,1.0);
        if(CK==1'b0 && D==1'b1)
        // arc RD --> Q
        if(CK==1'b1 && D==1'b0)
        // arc RD --> Q
        if(CK==1'b1 && D==1'b1)
        // arc RD --> Q
        $width(negedge CK,1.0,0,NOTIFIER);
        $width(posedge CK,1.0,0,NOTIFIER);
        $setuphold(posedge CK &&& (ENABLE_NOT_RD == 1'b1),
            negedge D &&& (ENABLE_NOT_RD == 1'b1), 1.0, 1.0, NOTIFIER);
            posedge D &&& (ENABLE_NOT_RD == 1'b1), 1.0, 1.0, NOTIFIER);
        $setuphold(posedge CK &&& (ENABLE_D == 1'b1), negedge RD &&& (ENABLE_D == 1'b1), 1.0, 1.0, NOTIFIER);
        $width(posedge RD,1.0,0,NOTIFIER);
  endspecify
  `endif // functional //
endmodule
`endcelldefine
发表于 2023-12-13 08:33:54 来自手机 | 显示全部楼层
你是跑rtl sim還是gate level sim帶sdf?
 楼主| 发表于 2023-12-13 10:12:02 | 显示全部楼层
pr之后的gate_level_sim带sdf
GMT+8, 2025-12-22 22:22 , Processed in 0.015298 second(s), 5 queries , Gzip On, Redis On.
