查看: 53352|回复: 229
[原创] 【McGraw-Hill 2005】Phase-Locked Loop Synthesizer Simulation 文字版
发表于 2008-2-1 21:36:45 | 显示全部楼层 |阅读模式
从网上一页一页copy下来的,花了不少时间,希望对大家有用。。。
[size=120%]Phase-Locked Loop Synthesizer Simulation (McGraw-Hill Electronic Engineering)
By Giovanni Bianchi
Publisher:   McGraw-Hill Professional
Number Of Pages:   227
Publication Date:   2005-03-09
ISBN-10 / ASIN:   0071453717
ISBN-13 / EAN:   9780071453714
Binding:   Hardcover
Book Description:
Phase locked loops (PLLs) are electronic circuits that ensure that a communications signal stays locked on a given frequency. Their design is crucial to the workings of wireless communications systems. Virtually all transceivers use PLLs to synthesize the stable, high frequency oscillations necessary for radio & wireless. This book describes how to calculate PLL performances by using standard mathematical or circuit analysis programs. Theoretical descriptions are limited to the minimum needed to explain how to perform calculations. Although presented methods of analysis can be implemented with many commercial programs, their description always refers to Mathcad and SIMetrix.
Download Description:
Summary: an indepth tutorial on Simetrix
Rating: 4
Bianchi offers both advice and code to perform simulations of phase locked loops. He develops enough theory for you to understand the key ideas. Though this is not a book on circuit theory per se; he suggests you consult other texts for that.
The accompanying CD has Mathcad and Simetrix engines. The Mathcad is the equivalent of Maple or Mathematica. It is unclear to me why he has chosen Mathcad over these. But for many readers, it is the Simetrix which will be more pertinent. It simulates analog and digital circuits. The analog portion is descended from the venerable Spice, which should be well known to any electrical engineer. You might consider the book as an indepth tutorial on Simetrix.
Phase-Locked Loop Synthesizer Simulation.rar
2.29 MB, 下载次数: 1213 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-2-1 21:50:46 | 显示全部楼层
辛苦!辛苦!
发表于 2008-2-1 22:08:06 | 显示全部楼层
thanks
发表于 2008-2-2 00:50:43 | 显示全部楼层
看看看看看
发表于 2008-2-2 00:55:24 | 显示全部楼层
看看看看看看
发表于 2008-2-2 01:04:34 | 显示全部楼层
感谢感谢!!
发表于 2008-2-2 05:43:56 | 显示全部楼层
感谢楼主!
发表于 2008-2-2 10:57:56 | 显示全部楼层
发表于 2008-2-2 16:58:38 | 显示全部楼层
先谢过
发表于 2008-2-2 19:22:27 | 显示全部楼层
Thanks!
GMT+8, 2025-12-24 21:22 , Processed in 3.252630 second(s), 6 queries , Gzip On, Redis On.
