查看: 1681|回复: 0
[求助] upf中的always on cell如何使用
发表于 2023-11-15 16:29:32 | 显示全部楼层 |阅读模式
在IEEE标准中看到有define_always_on_cell的命令,但是解释是:
The define_always_on_cell library command identifies the library cells having more than one set of power and ground pins that can remain functional even when the supply to the switchable power or ground pin is switched off.
显然是指定某一library cell的,但是如何使用always on cell我没有找到任何信息,请问有朋友知道吗
GMT+8, 2025-12-20 11:16 , Processed in 0.097368 second(s), 3 queries , Gzip On, Redis On.
