查看: 2738|回复: 4
[求助] AMS仿真遇到下面问题不知道如何解决
发表于 2023-11-10 21:01:03 | 显示全部楼层 |阅读模式
xrun: *N,CLEAN: Removing existing directory ./xcelium.d.
xrun: *W,DFLXW: The '-disable_ams_flex' option will be removed in a future XCELIUM release and only Flex mode will be available. To use Flex mode ensure that Spectre is set either using the '-spectre_path' option or Spectre is available in the system PATH.
xrun: *E,SPCERR: The program encountered one or more errors while processing the input SPICE file(s) in the AMSD flow. For details, see the following messages.
amsspice: *    ERROR (USIMPRS-17864): the radix card is not defined in this digital vector file.
amsspice: *Error: terminated with error code 2. If want to see more detailed message, set environment variable 'AMSSPICE_SPECTRE_DEBUG' to 'YES' and run again.
 楼主| 发表于 2023-11-10 21:02:56 | 显示全部楼层
AMSSPICE_SPECTRE_DEBUG设为YES了,Spectre的路径也是对的,还是报这个错误,我的模拟电路spectre是可以跑的,数字电路xrun也可以跑,结合起来就是这个错误。
发表于 2023-11-14 17:24:14 | 显示全部楼层
我也是这个问题。数模混合就跑不起来了,请求大神解惑
 楼主| 发表于 2023-11-28 20:40:21 | 显示全部楼层
兄弟,把cadence整个重新装就好了。
发表于 2023-11-29 16:59:30 | 显示全部楼层
工作量有点大嘞
GMT+8, 2025-11-12 22:18 , Processed in 1.413075 second(s), 3 queries , Gzip On, Redis On.
