查看: 1387|回复: 2
[求助] 综合出现的路径不认识,在网表种也搜不到怎么搞
发表于 2023-10-18 17:31:50 | 显示全部楼层 |阅读模式
是在check mv时报出来的很多warning,类似这种:
Warning: Pin 'u_gala/U_Mirror/code_out_reg[0]/Q'(VDD2[0.77v]) cannot drive 'u_gala/code_out_d1_reg[0]/next_state'(VDD_gala[0.88v]) due to voltage differences (effective strategy is [rule = low_to_high, threshold = 0.05]). (MV-231)
Warning: Pin 'sclk'(VDD1[0.88v]) cannot drive 'u_gala/U_Mirror/code_out_reg[0]/clocked_on'(VDD2[0.77v]) due to voltage differences (effective strategy is [rule = high_to_low, threshold = 0.05]). (MV-231)
但是这两条路径中的next_state和clocked_on并不是我rtl里面的东西,在综合的网表中也搜不到相应的关键字,这种warning该如何解决?
发表于 2023-10-18 18:23:56 | 显示全部楼层
这些object对应的是gtech netlist,说明这个报告是pre-compile吐出来的
看post-compile吐出来的check mv报告就好了,对应的是最终网表
 楼主| 发表于 2023-10-18 20:49:42 | 显示全部楼层
看post-compile吐出来的check mv报 ...
好的,非常感谢!!!!
GMT+8, 2025-12-20 15:36 , Processed in 0.013059 second(s), 4 queries , Gzip On, Redis On.
