查看: 2650|回复: 4
[求助] 带upf文件的dc综合报错The target library does not contain an inverter.
发表于 2023-10-12 20:02:32 | 显示全部楼层 |阅读模式
悬赏20资产已解决
具体的:
Error: The target_library does not contain an inverter characterized for operating condition (voltage = 1.080000V, process = 1.000000, temperature = 0.000000). (MV-006)
This problem occurred at:
    <top design>
Error: The target_library does not contain an inverter characterized for operating condition (voltage = 0.864000V, process = 1.000000, temperature = 0.000000). (MV-006)
Error: The target library does not contain an inverter.
        An inverter is required for mapping. (OPT-101)
请问各位大佬这种问题该从何处修改呢,刚开始接触upf设计,无从下手...
最佳答案
查看完整内容
printvar target_library
发表于 2023-10-12 20:02:33 | 显示全部楼层
 楼主| 发表于 2023-10-15 10:37:35 | 显示全部楼层
好像就是引用target library的问题,我还想请教一下,是不是综合时会有包括isolation cell 、level shifter cell等低功耗单元的专有library,必须引用上才能完成综合,否则还是会报warning等信息?
发表于 2024-8-28 23:11:32 | 显示全部楼层
SGengiant 发表于 2023-10-15 10:37
好像就是引用target library的问题,我还想请教一下,是不是综合时会有包括isolation cell 、level shift ...
大佬 我最近也碰到了一样的问题,不知道怎么解决,请问当时您是怎么修改的呢。我是target library里面放了std cell library和装有isolation cell、shifter 等低功耗的library,load upf之后,再insert mv cell的时候报出和你特别类似的error:
Error: The target_library does not contain an inverter characterized for operating condition (voltage = 0.810000V, process = 1.000000, temperature = -40.000000). (MV-006)
    <top design>
我的library default operation condition都是voltage 0.81,process 1以及temperature -40,不知道从哪下手改
发表于 2024-8-30 17:35:59 | 显示全部楼层
upf是不是有高低压?把低压库也读进去就行了
如果没有高低压检查一下target_library吧?你是不是库没加全
GMT+8, 2025-12-21 02:28 , Processed in 0.017346 second(s), 4 queries , Gzip On, Redis On.
