查看: 2674|回复: 1
[求助] 使用clsAdminTool解锁时出现segmentation fault(core dumped)
发表于 2023-9-19 17:09:08 | 显示全部楼层 |阅读模式
virtuoso中cell的schematic被锁住后在网上找到解决办法,使用clsAdminTool指令即可解决,第一次输入好像是有效的,但后面不知道为什么就无法使用这个指令了。
在Terminal输入clsAdminTool -ale ./就会出现Segmentation fault (core dumped),输入clsAdminTool -help出现
  1. /.../cadence/INCISIVE151/tools/bin/clsAdminTool[79]: .[1035]:.:ine 83:16596:Memory fault(coredump)
  2. #For detailed help on these generic options,use:
  3.      /.../cadence/INCISIVE151/tools/bin/clsAdminTool -help3264
  4. Segmentation fault (core dumped)
    复制代码
这个要怎么解决呢?
发表于 2023-9-19 17:19:36 | 显示全部楼层
#在这里快速回复#Usage (batch mode):   clsAdminTool [-help] [-version] [-force]        -ale <directoryHierarchy>           List all Edit Locks in directoryHierarchy        -aple <directoryHierarchy> <hostname> [pid [processCreationTime]]           List all Edit Locks of process pid in directoryHierarchy        -are <directoryHierarchy>           Release all Edit Locks in directoryHierarchy        -apre <directoryHierarchy> <hostname> <pid> <processCreationTime>           Release all Edit Locks of process pid in directoryHierarchy        -asre <filePath>           Release Edit Lock on the file specified by filePath
GMT+8, 2025-12-19 20:48 , Processed in 0.013058 second(s), 5 queries , Gzip On, Redis On.
