查看: 2936|回复: 5
[求助] 模数混仿真amsPLL问题
发表于 2023-9-16 13:58:55 | 显示全部楼层 |阅读模式
Netlist Error: Cannot find any info on instance "NM0" in cell-view "amsPLL" "PLL_VCO_INV" "schematic"
Netlist Error: Some cell-views used inside this block could not be netlisted in analog context
Netlist Error: Cannot find any info on instance "PM10" in cell-view "amsPLL" "PLL_VCO_REG" "schematic"
Netlist Error: Cannot find any info on instance "PM2" in cell-view "amsPLL" "PLL_VCO_CMOSDVR" "schematic"
Netlist Error: Cannot find any info on instance "NM0" in cell-view "amsPLL" "PLL_VCO_320MHZ_INV" "schematic"
Netlist Error: Cannot find any info on instance "R14" in cell-view "gpdk090" "resnsppoly" "schematic"
Netlist Error: Cannot find any info on instance "NM1" in cell-view "amsPLL" "PLL_160MHZ_LF" "schematic"
Netlist Error: Cannot find any info on instance "C4" in cell-view "amsPLL" "PLL_160MHZ" "schematic"
Netlist Error: Cannot find any info on instance "R0" in cell-view "gpdk090" "resnsppoly" "schematic"
WARNING (VLOGNET-110): The cell 'ZZZZZZ/PLL_160MHZ_sim/schematic' has no ports. Make sure that this was the intended
design.
ERROR (OSSHNL-514): Netlist generation failed because of the errors reported above. The netlist might not have been generated at all, or the generated netlist could be corrupt. Fix the reported errors and regenerate the netlist.
*ERROR* (AMS-1247): AMS UNL netlisting has failed.
Check Simulation->Output Log->Netlister Log for errors.
Correct your design and netlist again.
      ...unsuccessful.
 楼主| 发表于 2023-10-4 19:02:25 | 显示全部楼层
这个问题应该是Spectre model问题
发表于 2023-10-11 10:26:31 | 显示全部楼层
Hi 楼主怎么解决的呀,我也碰到了相同的问题
发表于 2024-3-1 22:26:27 | 显示全部楼层
请问一下楼主解决了吗
发表于 2024-3-1 22:45:38 | 显示全部楼层
66ZQ333 发表于 2024-3-1 22:26
请问一下楼主解决了吗
请问您解决这个问题了吗
发表于 2024-3-9 00:16:53 | 显示全部楼层
66ZQ333 发表于 2024-3-1 22:45
请问您解决这个问题了吗
你解决了吗
GMT+8, 2025-12-27 17:15 , Processed in 0.016747 second(s), 5 queries , Gzip On, Redis On.
