查看: 2004|回复: 2
安装PDK时遇到Error "BadAtom
发表于 2023-9-8 23:36:30 | 显示全部楼层 |阅读模式
最近使用到BCD工艺,正常解压后安装遇到这个问题,各位大哥哥大姐姐遇到过这个问题吗?求解决!
列出错误代码
Virtuoso version should be IC616ISR500 or above
NOTICE: This PDK only contains RC extraction files for below metal options:
        (1) 1P5M for 2 topmetal=8K+40k(1TM1_1MTT2), 2fF mim between M3 & M4   (mim2_ckt), HRP 3K
        (2) 1P5M for 1 topmetal=33k(1TM2), 2fF mim between M3 & M4   (mim2_typ2_ckt), HRP 3K
        (3) 1P6M for 2 topmetal=8K+40k(1TM1_1MTT2), 2fF mim between M3 & M4   (mim2_typ2_ckt), HRP 3K
        (4) 1P6M for 1 topmetal=33k(1TM2), 2fF mim between M3 & M4   (mim2_typ2_ckt), HRP 3K
        For other metal options, user can download RC files from SMICNOW,
        or raise request if no such supply, we will deliver upon request.
NOTICE: Please run "virtuoso -nograph" command in terminal to debug if the
        cadence tool can't be launched successfully!!!
This script will launch /etc/env/virtuoso to set the library.
@(#)$CDS: spectre  version 15.1.0 64bit 11/12/2015 19:02 (sjfnl729) $
@(#)$CDS: virtuoso version 6.1.7-64b 11/09/2015 12:45 (sjfnl165) $
\e Display :0.0 Error "BadAtom (invalid Atom parameter)"
\e  request 20 error 5 serial 229
发表于 2023-9-9 12:45:42 | 显示全部楼层
看错误是xwindows的display 问题
发表于 2025-1-4 23:23:14 来自手机 | 显示全部楼层
兄弟,你遇到的问题解决了吗
GMT+8, 2025-12-21 12:31 , Processed in 0.012705 second(s), 3 queries , Gzip On, Redis On.
