查看: 2683|回复: 4
ADS的layout进行EM仿真,警告
发表于 2023-8-28 14:36:40 | 显示全部楼层 |阅读模式
在ADS的layout进行EM仿真,出现以下两个警告。
WAENING1:
Accuracy can be lost due to matrix compression,you can rerun the simulation with reduced compression level or with the direct dense solver to verify the results.
WARNING2:
S-parameter data show unphysical behavior for certain frequences.
Cause: - electrically large port size
           - electrically large via using lumped model
           - mesh density is too coarse
           - matrix solver compression is too high
           - inaccurate (high frequency) calibration
警告一:按照提示reduced compression level之后,依旧有该警告;
警告二:S参数仿真结果不准确,不知道如何解决。
ADS仿真警告
ADS仿真警告
发表于 2025-4-10 15:36:51 | 显示全部楼层
你好,题主有结果了,我有时候会遇到这种warning,有的时候却遇不到。
题主是什么工艺,SMIC的吗?
 楼主| 发表于 2025-6-30 11:36:16 | 显示全部楼层
题主是什么工艺,SMIC的吗? ...
GlobalFoundary工艺
发表于 2025-10-28 11:22:04 | 显示全部楼层
Yonion 发表于 2025-6-30 11:36
GlobalFoundary工艺
楼主有解决吗
 楼主| 发表于 2025-10-29 14:59:42 | 显示全部楼层
loaf123 发表于 2025-10-28 11:22
楼主有解决吗
没有
GMT+8, 2025-11-7 05:05 , Processed in 0.022251 second(s), 4 queries , Gzip On, Redis On.
