查看: 2038|回复: 2
[求助] QRC抽取寄生问题
发表于 2023-8-24 10:53:34 | 显示全部楼层 |阅读模式
calibre2qrc产生lvsfile文件,报错加密怎么解决
WARNING: Encryption is not supported and removed.
WARNING: DMACRO embedded encryption may cause unknown outcome.
manual里面的解释
When encryption occurs inside a DMACRO definition, calibre2qrc will add the missing end brackets (`]}') so it can correctly translate the rule deck. When this happens the following warning will be reported:
WARNING: Encryption inside DMACRO may cause unknown outcome.
You should manually comment out encrypted sections of a Calibre rule deck prior to running calibre2qrc to avoid problems and insure proper execution.
但是不知道怎么做,有没有大佬解释一下
发表于 2024-11-10 18:10:46 | 显示全部楼层
遇到了相同的问题,能请问一下您是怎么解决的吗?
 楼主| 发表于 2024-11-12 11:00:16 | 显示全部楼层
没用这个了,用capgen文件产生的
GMT+8, 2025-12-19 19:27 , Processed in 0.013126 second(s), 4 queries , Gzip On, Redis On.
