查看: 1635|回复: 0
PSS Sincal 19.0 x64 with Complete Features
发表于 2023-8-14 17:32:36 | 显示全部楼层 |阅读模式
PSS Sincal 19.0 with Complete Features
PSS®SINCAL – simulation software for analysis and planning of electric and pipe networks. PSS®SINCAL is used in over 100 countries by transmission and distribution planning engineers, protection engineers, consultants, power plant and industrial network operators, operations planning engineers, IT professionals , researchers, and more.
PSS®SINCAL is part of the curated and modular Siemens Xcelerator portfolio. Siemens Xcelerator is an open digital business platform that enables you to accelerate your digital transformation easier, faster and at scale.
PSS®SINCAL offers a variety of modules for the design, modeling, and analysis of electrical and pipe networks. Learn how to leverage the PSS®SINCAL tools to tackle the different challenges of the changing grid.
Features:
  • Independently or simultaneously analyze the impacts of low, medium, and high-voltage networks
  • Reliably plan new networks, grid expansions, and adaptations
  • Streamline the integration an assessment of renewable energy
  • Integrated Transmission & Distribution System Analysis
  • Power System Protection Analysis
  • etc.
New Module: Thermal Destruction Analysis (TDA)
The operating equipment of the network must be designed to withstand short-circuits. Until now, this required extensive manual short-circuit calculations for the entire network area, considering the clearing times of the network protection.
The new module Thermal Destruction Analysis enables both the network planning and the protection department to perform an automated check for thermal destruction for all lines, transformers, busbars and breakers in the network.
As a result, the user receives a clear representation of all the checked equipment with simulation results showing thermally destroyed elements. A detailed analysis in the network is directly accessible from the results view. Based on the results, measures regarding network protection or network reinforcement can be derived and their effectiveness can be checked by the Thermal Destruction Analysis.
Wide range of UX and UI improvements based on user and internal ideas
Thanks to all our PSS®SINCAL users who submit & review ideas through the PSS® Ideas Portal. We are thrilled to highlight four of many ideas which are implemented:
  • Click and drag for labels in protection documentation diagrams:
  • Deleting network data without graphics:
  • Creation of heatmaps based on the bus voltage angle:
Along with the PSS® Ideas Portal ideas, the upcoming release will include several UX/UI improvements based on your direct feedback to the PSS®SINCAL team, including:
  • Direct link from graphical elements to settings dialogues or network element data
  • Autodetection and opening of network graphic views containing the element to select in network browser, tabular view, etc.
  •   Simplified functionality to switch between network graphic evaluation filters in the UI
  • Revisited and reconstructed input data dialogs for controllers (transformer tap changers and shunt elements) according to the user workflow.
Extension in short circuit calculation
It is getting increasingly important to consider the short-circuit current contributions from converter driven plants. The extensions in the short-circuit calculation standard   G74 Issue 2   shows exactly this.
With PSS®SINCAL 19.0, this new standard is supported.
Furthermore, the short-circuit current contribution capabilities of converter driven plants are extended to reflect the real converter behavior as realistic as possible. This can be used to extend other short-circuit calculation standards like the IEC 60909 and all calculation methods making use of short -circuit calculations (eg protection simulation).
For more information about PSS Sincal 19.0 x64, please contact      fast.forever24@gmail.com
GMT+8, 2025-12-30 01:40 , Processed in 0.042419 second(s), 5 queries , Gzip On, Redis On.
