查看: 2047|回复: 2
[求助] Cadence Nc-Verilog
发表于 2023-8-7 09:52:53 | 显示全部楼层 |阅读模式
我正在尝试使用Virtuoso中的NC-Verilog对我的原理图进行仿真。当我单击simuate时,我不断收到以下错误:
irun: *E,FMUK: The type of the file (/counter_run1/testfixture.template) could not be determined.
irun: *E,FMUK: The type of the file (ihnl/cds0/netlist) could not be determined.
irun: *E,FMUK: The type of the file (ihnl/cds1/netlist) could not be determined.
irun: *E,FMUK: The type of the file (ihnl/cds2/netlist) could not be determined.
irun: *E,FMUK: The type of the file (ihnl/cds3/netlist) could not be determined.
irun: *E,FMUK: The type of the file (ihnl/cds4/netlist) could not be determined.
irun: *E,FMUK: The type of the file (ihnl/cds5/netlist) could not be determined.
irun: *E,FMUK: The type of the file (ihnl/cds6/netlist) could not be determined.
irun: *E,FMUK: The type of the file (ihnl/cds7/netlist) could not be determined.
irun: *E,FMUK: The type of the file (ihnl/cds8/netlist) could not be determined.
irun: *E,FMUK: The type of the file (ihnl/cds9/netlist) could not be determined.
irun: *E,FMUK: The type of the file (ihnl/cds10/netlist) could not be determined.
irun: *E,FMUK: The type of the file (ihnl/cds11/netlist) could not be determined.
irun: *E,FMUK: The type of the file (ihnl/cds12/netlist) could not be determined.
irun: *E,FMUK: The type of the file (ihnl/cds13/netlist) could not be determined.
请问一下如何解决这个问题?谢谢。
发表于 2023-8-7 10:30:36 | 显示全部楼层
是不是connect rules没有配置
 楼主| 发表于 2023-8-7 11:24:49 | 显示全部楼层
nc-verilog也需要设置connect rules嘛?需要怎么设置哇?
GMT+8, 2025-12-26 14:42 , Processed in 0.445595 second(s), 4 queries , Gzip On, Redis On.
