楼主: noland
[求助] SPICE MODEL怎么导入virtuoso进行仿真
发表于 2024-3-29 11:09:48 | 显示全部楼层
太玄感应 发表于 2023-7-25 08:19
可以参考这个
感谢老哥的文档,救我于水火
发表于 2024-5-22 19:58:42 | 显示全部楼层
suncold 发表于 2023-7-25 15:55
盲猜你手头的是Pspice模型
在你的仿真库里面新建一个cellView,类型选“Pspice”,然后把模型贴进去(都是 ...
您好,我用了您的方法但是报错了,报错如下:
ERROR (OSSHNL-116): Cannot descend into any of the views defined in the view list 'spectre cmos_sch cmos.sch schematic veriloga' specified
for library 'NN' and cell 'dercet_add' for the instance 'I3' in cell 'NN/dercet_add_tb/schematic'. Add
one of these views or modify the view list so that it contains an existing view.
End netlisting May 22 07:20:57 2024
ERROR (OSSHNL-514): Netlist generation failed because of the errors reported above. The netlist might not have been generated at all, or the generated netlist could be corrupt. Fix the reported errors and regenerate the netlist.
      ...unsuccessful.
*Error* failed at creating netlist
发表于 2024-5-23 11:14:19 | 显示全部楼层
ERROR (OSSHNL-116): Cannot descend into any of the view ...
报错信息已经告诉你原因了啊,nestlister无法识别pisce view
解决方法:
ADE菜单“Setup - Environment”,然后在第一行“Switch View List”里面加上“pspice”项,如图:
发表于 2024-5-23 14:33:06 | 显示全部楼层
解决方法:
感谢感谢,解决了。刚开始用,还不太了解软件
发表于 2024-12-5 13:37:05 | 显示全部楼层
thanks
发表于 2025-1-30 23:19:52 | 显示全部楼层
謝謝分享
发表于 2025-3-7 01:00:12 | 显示全部楼层
盲猜你手头的是Pspice模型
生成symbol的时候symbol的脚怎么对应?
GMT+8, 2025-9-18 03:05 , Processed in 0.022025 second(s), 3 queries , Gzip On, Redis On.
