查看: 1291|回复: 0
Openram 生成memory corner 问题请教
发表于 2023-7-13 13:27:34 | 显示全部楼层 |阅读模式
使用openram 生成memory ,按照往网上配置,结果出来corner  lib 是  FF_1p0V_25C 和 SS_1p0V_25 ,有知道什么哪里设置问题吗?
nominal_corner_only = False# Or you can specify particular corners# Process corners to characterizeprocess_corners = ["SS", "TT", "FF"]# Voltage corners to characterizesupply_voltages = [ 0.9, 1.0, 1.1 ]# Temperature corners to characterize# temperatures = [ 0, 25, 100]
GMT+8, 2025-10-22 19:20 , Processed in 0.010740 second(s), 3 queries , Gzip On, Redis On.
