查看: 1721|回复: 1
[求助] ICC在加入网标文件出现The tool has just encountered a fatal error
发表于 2023-6-21 10:06:41 | 显示全部楼层 |阅读模式
大家好!小弟近日使用ICC进行自动布局布线时,想完整跑一遍流程,流程还没走完,ICC就崩溃了,自动退出,出现了这样的问题,在经过几天的搜索之后仍旧未能解决。希望各位前辈帮助一下,谢谢了。
****  Verilog HDL translation! *****
*****    Start Pass 2 *****
Compiling source file /home/ic_lab/YTF/ICC_project/H265/src/enc_core.v
Warning: Cell 'ram_1p.CEL' is created for undefined module 'ram_1p'. (MWNL-294)
Warning: Cell 'sram_sp_be_behave.CEL' is created for undefined module 'sram_sp_be_behave'. (MWNL-294)
Warning: Inconsistent port connection of port "adr" in cell "sram_sp_be_behave".. (MWNL-178)
Warning: Inconsistent port connection of port "wr_ena" in cell "sram_sp_be_behave".. (MWNL-178)
Warning: Inconsistent port connection of port "wr_dat" in cell "sram_sp_be_behave".. (MWNL-178)
Warning: Inconsistent port connection of port "rd_dat" in cell "sram_sp_be_behave".. (MWNL-178)
The tool has just encountered a fatal error:
If you encountered this fatal error when using the most recent
Synopsys release, submit this stack trace and a test case that
reproduces the problem to the Synopsys Support Center by using
Enter A Call at http://solvnet.synopsys.com/EnterACall.
* For information about the latest software releases, go to the Synopsys
  SolvNet Release Library at http://solvnet.synopsys.com/ReleaseLibrary.
* For information about required Operating System patches, go to
  http://www.synopsys.com/support
Fatal: Internal system error, cannot recover.
Release = 'O-2018.06-SP1'  Architecture = 'linux64'  Program = 'icc_shell'
Exec = '/EDA/synopsys/ic_compiler_vO-2018.06-SP1/linux64/syn/bin/galaxy_icc_exec'
'6116775 253205313 253208234 139723399194240 203025759 203061498 202902535 122025181 121930174 122522864 202900869 155921343 111188347 49868981 47987849 43627127 223179047 223322880 257043829 257063303 257722099 223311645 34253269 34233408 35430758 35437862 35438785 35440652 33257908 13831266 13834865 268035232 264933297 262402507 262407385 262407653 259559398 259226388 259253074 33777612 267953037 259250917 259718130 259710487 259861749 27257189 267967496 27255323 257876608 27256978 267947733 267948565 267970592 33682391 6134063 38719567 6131864 5947652 139723364574165'
 楼主| 发表于 2023-6-29 20:48:55 | 显示全部楼层
求救啊
GMT+8, 2025-11-8 20:10 , Processed in 1.333318 second(s), 4 queries , Gzip On, Redis On.
