查看: 2303|回复: 1
[求助] set_fp_pin_constraints 约束后失败出现问题
发表于 2023-6-7 18:55:09 | 显示全部楼层 |阅读模式
对一个spi数字电路跑后端,由于是模拟电路的一部分,所以不需要加pad,
使用pin_con.tcl文件约束顶层port
set_pin_physical_constraints -pin_name {PORB_I} -layers {METAL3} -width 0.6 -depth 0.6 -side 1 -order 1
set_pin_physical_constraints -pin_name {RST} -layers {METAL3} -width 0.6 -depth 0.6 -side 1 -order 2
set_pin_physical_constraints -pin_name {CLK} -layers {METAL3} -width 0.6 -depth 0.6 -side 1 -order 3
set_pin_physical_constraints -pin_name {CS_I} -layers {METAL3} -width 0.6 -depth 0.6 -side 1 -order 4
icc log如下:
icc_shell> remove_pin_pad_physical_constraints -pin_only
1
icc_shell> read_pin_pad_physical_constraints ./scripts/pin_con.tcl
1
icc_shell> set_fp_pin_constraints -block_level -no_stacking all -pin_spacing 2
1
icc_shell> place_fp_pins -block_level
Warning: Cell instance u_spi_slave\/u_spi_fsm\/opcode_tmp_reg[3] is not completely placed inside top block data_setup (FPHSM-1800)
Warning: Current cell: cell placement is incomplete and will be ignored (FPHSM-1829)
Warning: Unable to assign physical constrained pin PORB_I at all. Treat it as an ordinary pin from now on. (FPHSM-1613)
Warning: Unable to assign physical constrained pin OUT_O[47] at all. Treat it as an ordinary pin from now on. (FPHSM-1613)
Warning: Unable to assign physical constrained pin OUT_HIZ_O[49] at all. Treat it as an ordinary pin from now on. (FPHSM-1613)
Warning: Failed to find legal slot for pin CS_I. Violating pin constraints to find pin slot ... (FPHSM-1447)
Warning: Unable to legally place pin data_setup/CS_I on physical constraint specified SM edge (FPHSM-1801)
Error: Failed to find any slot for pin CS_I. (FPHSM-0829)
Warning: Pin placement did not place any pin!. (FPHSM-0101)
Name         Original Ports
data_setup                0
Warning: Pin placement is skipped because there are no placeable soft macro pins. (FPHSM-1846)
1
请问有没有人知道是什么原因,怎么解决呀
发表于 2024-12-27 15:41:10 | 显示全部楼层
请问这个pin位置不能被约束得问题解决了吗,我也遇到这个问题了
GMT+8, 2025-12-13 23:09 , Processed in 0.012074 second(s), 4 queries , Gzip On, Redis On.
