查看: 1948|回复: 4
PathWave Electrical Performance Scan (EP–Scan) 2023 Update1
发表于 2023-6-2 06:18:10 | 显示全部楼层 |阅读模式
PathWave Electrical Performance Scan (EP–Scan) 2023 Update 1
Keysight Technologies, Inc., a leading technology company that delivers advanced design and validation solutions to help accelerate innovation to connect and secure the world, introduces the Electrical Performance Scan (EP-Scan) 2023, a new high-speed digital s simulation tool that supports rapid signal integrity (SI) analysis for hardware engineers and printed circuit board (PCB) designers.
Keysight Introduces Signal Integrity Simulation Software for Hardware Engineers
After completing a PCB design, hardware engineers hand the design over to SI specialists to validate its performance before going to prototype. SI specialists perform simulations on a large number of nets, which can take days to weeks to complete. As a result, hardware eng ineers have difficulty predicting how much analysis time it will take to find errors or performance issues in the design. Uncertainty about the length of the SI analysis phase creates a bottleneck in the design cycle and delays time-to-market.
EP-Scan addresses SI analysis bottlenecks by giving hardware designers diagnostic tools to correct designs earlier and meet development schedules. As a stand-alone software product, EP-Scan performs electromagnetic (EM) simulation on signal nets and reports SI metrics such as channel return and insertion loss. In addition, EP-Scan automates performance comparisons between different versions of a design and generates simulation reports that expedite verification prior to building expensive physical prototypes.
EP-SCAN Requires Only the Layout Geometry and Substrate Stack-Up Information for the PCB Design As Inputs. After Engineers Specified Nets For Investigat ION, EP-SCAN Reports Simulation Results Including the Characteristic Impedance and Delay of Traces, Return Loss, Inserty Loss , and impedance time-domain reflectometry (TDR). By analyzing common fabrication formats such as ODB++, EP-Scan shows engineers the performance of their design as it would be when fabricated. EP-Scan enables hardware engineers to quickly validate designs and identify layout issues before the final verification, which reduces time-to-market, and can contribute to more PCB design wins.
Keysight's PathWave , an open, scalable, and predictive software platform, offers fast and efficient data processing, sharing and analysis at every stage in the product development workflow. Combining design software, instrument control and application-specific test software, it enables s engineers to address increasing design, test, and measurement complexity and developing optimal electronic products.
PathWave High-Speed ​​Digital Applications (HSD Apps) provides signal integrity software to help hardware engineers and printed circuit board designers create high-speed design prototypes, perform validation, and generate performance reports. Each application is lightweight and requires little effort to be productive.
PathWave Electrical Performance Scan (EP-Scan) enables hardware design engineers to import ODB++ layouts and perform preliminary signal integrity analysis quickly. Analysis results include trace impedance, time delay, channel S-parameters, TDR impedance Description. The software checks for violation against standard specification and can generate simulation reports.
*****Please note*****
If you are interested in the full licensed software  PathWave Electrical Performance Scan (EP–Scan) 2023 Update 1 with full feature license, then do well to contact     fast.forever24@gmail.com
发表于 2023-6-2 07:21:23 | 显示全部楼层
可以的
发表于 2023-6-2 08:05:01 | 显示全部楼层
kan e kan
发表于 2023-6-2 08:26:06 | 显示全部楼层
发表于 2023-6-2 17:10:47 | 显示全部楼层
thanks
GMT+8, 2025-12-26 09:13 , Processed in 0.015005 second(s), 3 queries , Gzip On, Redis On.
