查看: 4991|回复: 12
Mentor Graphics Xpedition Enterprise VX.2.13 Win x64
发表于 2023-6-2 04:29:48 | 显示全部楼层 |阅读模式
Mentor Graphics Corporation, a Siemens business, is pleased to announce the availability of Xpedition Enterprise VX.2.13. The latest release has improvements across three key areas: layout, data management and verification.
What's New in Xpedition VX.2.13
Xpedition Enterprise Flow
The Xpedition Enterprise Flow has been enhanced with a number of new features that improve product usability and efficiency in the X-ENTP VX.2.13 release.
Xpedition AMS
Xpedition AMS includes the following new features and updates in release VX.2.13:
- SPICE Syntax Checker: Release VX.2.12 introduced the SPICE syntax checker, which checks non-PSpice models for syntax errors based on the Xpedition AMS required syntax. Release VX.2.13 updates the checker with syntax checks and sup port for additional SPICE models. The syntax checker can run automatically at simulator startup, or from a dialog started from the new Simulation > Check Spice Model menu option. To view the menu option, set the following Windows environment variable: SV_ADVANCED=1.
- PSpice Converter Updates: Circuit net names starting with "+" and "-" are properly converted to Xpedition AMS syntax. For example +VSIG and -VSIG will be converted to N+VSIG and N-VSIG, respectively. And in some commands that require minimum and maximum limits, PSpice allows the order definition to be min then max, or max then min. Xpedition AMS only supports min then max, so the PSpice converter now corrects the order as needed.
- Simulation Progress Counter Updates: The simulation progress counter, which is visible in the lower left-hand corner of the Xpedition AMS window during a simulation, now accommodates analyzes that combine the .SWEEP and .EXTRACT commands.
- Tutorial Updates: Tutorial updates include changes to the SPICE Import, Parametric Analysis, S-Parameter, and FFT tutorials. All tutorials are available from the Help > AMS Tutorials > Tutorial Index menu option.
Xpedition Enterprise is the industry's most innovative PCB design flow, providing integration from system design definition, electronics design, electro-mechanical co-design, simulation and verification, all the way to PCB manufacturing. Its unique, patented technologies can reduce design cycle s by 50 percent or more, while significantly improving overall quality and resource efficiency.
The latest Xpedition VX.2.13 release of Xpedition has improvements across three key areas: Layout, data management, and verification. New layout capabilities include additional physical reuse use cases, tear drop creation, as well as new key-in shortcuts. Coll labor is improved through EDM, with better display and reporting of managed block data. AMS simulation has an improved syntax checker and new tutorials.
*****Please note*****
If you are interested in the full licensed software Mentor Graphics Xpedition Enterprise VX.2.13 Win x64 with full feature license, then do well to contact     fast.forever24@gmail.com
发表于 2023-6-6 21:44:37 | 显示全部楼层
太感谢了
发表于 2023-6-6 21:48:02 | 显示全部楼层
太感谢了
发表于 2023-8-18 12:33:04 | 显示全部楼层
THANKS
发表于 2023-9-29 23:31:02 | 显示全部楼层
太感谢了
发表于 2023-11-24 17:21:10 | 显示全部楼层
所以请问怎么下载,联系邮箱吗
发表于 2023-11-27 22:06:00 | 显示全部楼层
kankan thanks
发表于 2023-12-13 11:29:14 | 显示全部楼层
谢谢
发表于 2023-12-13 11:30:06 | 显示全部楼层
太好了!!!!
发表于 2024-2-8 00:03:07 来自手机 | 显示全部楼层
哪里可以下载?
GMT+8, 2025-12-29 02:07 , Processed in 0.019006 second(s), 3 queries , Gzip On, Redis On.
