查看: 5783|回复: 11
Cadence Spectre 23.10.063 (2023 Version)
发表于 2023-6-2 04:21:04 | 显示全部楼层 |阅读模式
The software developer Cadence Design Systems, Inc. is pleased to announce the availability of Specter 23.10.063 is an advanced circuit simulator that simulates analog and digital circuits at the differential equation level.
2564491 AMSD expression using digital signal results in eval err in AMS analog fault simulation
2598117 FX request to change the print in log for module BA option
1850884 SPECTRE Difference in transient noise and AC noise for a vsource noisefile
2136967 SPECTRE Enhance dyn_floatdcpath check to support wildcard for nonconducting_subckt=[simplebjt_*]
2434152 SPECTRE Parameterizing hisim_hv version number and setting it to 2.4 causes version 2.1 to be used
2459355 SPECTRE dyn_floatdcpath with sweep=single takes days and needs better performance
2484133 SPECTRE Provide a way to output the values ​​of all Specter options to the output file
2527929 SPECTRE Specter exits unexpectedly when +preset=lx is used with n16; +aps and spectre X with mx run fine
2544560 SPECTER dyn_float_tran_state: domain detection wrong if domains=[VPOS VNEG] and V(VPOS)=-V(VNEG);
2546231 SPECTRE Output Specter process IDs in the license traceinfo in License Manager
2554158 SPECTRE The feature that saves a dcOpInfo file for each DC sweep point does not work when the swept variable is temperature
2555309 SPECTRE Info analysis for a custom inserter should support faultlocal option, redundancy check, annotation of terminals and devs
2556147 SPECTRE Incorrect BJT dcop current in Specter X
2556579 SPECTRE Specter APS: Enhancement in Specter that controls the op point info for each dc sweep point is not working
2557581 SPECTRE misleading SFE-401 error message when there are two identical instances in SPF file
2558135 SPECTRE Specter transient stops progressing when using a dynamic parameter on a design variable
2560268 SPECTRE Add support for extended Open MOS gate fault model
2567170 SPECTRE Reliability Report view does not show AgeMOS instances for native TMI+AgeMOS
2568789 SPECTRE Specter X inaccuracy with spef stitching
2569235 SPECTRE Does transient noise with vsource/noisefile support a noisefile with a spectrally shaped profile?
2571088 SPECTRE Specter APS segmentation fault error in Specter 20.1 ISR8 and newer versions
2572231 SPECTRE Specter X reporting incorrect waveform units when using psfxl
2576129 SPECTRE Error in post-layout simulation when instances are written in mixed case
2576916 SPECTRE The effect of temperature is ignored in the post layout flow that uses dspf_include
2577172 SPECTRE Support a new option to disable hisim_hv she model in legato thermal simulation
2577618 SPECTRE In direct method, add_pin does not add pins at a specified layer
2580185 SPECTRE Specter exits unexpectedly while running element info analysis on a customer testcase
2580952 SPECTRE Need to speed up Specter X further
2580955 SPECTRE Support maximum Gm delta_Vth and constant current to calculate delta_Vth
2581739 SPECTRE No aging with URI aging models
2581875 SPECTRE Enhance info analysis to support the generation of duplicates of structural defects when faultcollapse=no
2582777 SPECTRE spectre_ddmrpt produces incorrect results when merging table files
2582808 SPECTRE Incorrect reporting of grid capacitance in PowerGrid Views report for one switch net
2583132 SPECTRE enable_dcsweep_op_info=yes does not work when multiple instances refer to a var that is swept in DC sweep analysis
2583171 SPECTRE Main Specter process for a high-sigma Monte Carlo run stops responding even if all subprocesses are run successfully
2585125 SPECTRE Specter Ignore Spice Syntax Options Parhier on SPECTRE_20.1ISR10 And Later Version
2587079 SPECTRE Segmentation fault near AHDL/ahdlcmi module compilation
2588638 SPECTRE A Monte Carlo run in Specter MDL exits unexpectedly due to the limited number of files opened
2591950 SPECTRE Simulation error in fault simulation with SFE-3318 warning in the log file
2593192 SPECTRE Specter stops unexpectedly while using emirpreset for EMIR simulations
2596089 SPECTRE Incorrect relationship between Phase and Flux observed when using JJ model 1.17
2601869 SPECTRE Simulation fails in Specter 21.1 ISR3 when an invalid instance parameter is specified for a primitive 'resistor'
2605048 SPECTRE Issues with $simprobe expressions used in VerilogA module
As the industry's leading solution for accurate analog simulation, the Cadence Specter Simulation Platform contains multiple solvers to allow a designer to move easily and seamlessly between circuit-, block-, and system-level simulation tasks. The foundation of the platform is a unified set of technologies shared by all of the SPICE engines-the parser, device models, Verilog-A behavioral modeling, input data formats, output data formats, etc.-thereby guaranteeing consistent and accurate evaluation methods regardless of the simulator selected.
The simulator uses improved algorithms that offer increased simulation speed and greatly improved convergence characteristics over SPICE. Besides the basic capabilities, the Specter circuit simulator provides significant additional capabilities over SPICE. Verilog-A use s functional description text files (modules) to model the behavior of electrical circuits and other systems. Specter RF Simulation option adds several new analyzes that support the efficient calculation of the operating point, transfer function, noise, and distortion of common RF and communication circuits, such as mixers, oscillators, sample holds, and switched- capacitor filters.
Cadence technology platforms, including Xcelium Logic Simulation, Liberate Trio Characterization Suite, Legato Reliability Solution, Virtuoso ADE Product Suite, Voltus-Fi Custom Power Integrity Solution, and the Virtuoso RF Solution, to provide the industry's most comprehensive ive cross-domain simulation solution The Specter Simulation Platform delivers an indus-try-leading set of technologies for a comprehensive design and verification solution that provides SPICE, radio frequency (RF), FastSPICE, and mixed-signal simulators in a unique shared licensing package. This unified solution delivers scalable per form and capacity , thus providing robust verification of analog, RF, memory, custom digital, and mixed-signal silicon realization.
*****Please note*****
If you are interested in the full licensed software Cadence Spectre 23.10.063 with full feature license, then do well to contact     fast.forever24@gmail.com
发表于 2024-12-27 09:38:56 | 显示全部楼层
look look
发表于 2024-12-27 11:02:46 | 显示全部楼层
thanks
发表于 2024-12-27 11:33:14 | 显示全部楼层
thanks
发表于 2024-12-31 11:09:34 | 显示全部楼层
666666
发表于 2024-12-31 12:51:21 | 显示全部楼层
hummmm.....
发表于 2025-4-14 21:59:39 | 显示全部楼层
请问右都督的吗w
发表于 2025-4-14 22:00:43 | 显示全部楼层
有没有单独的Spectre2023安装包呀
发表于 2025-5-6 23:11:07 | 显示全部楼层
hummmmmmmm
发表于 2025-5-14 13:40:56 | 显示全部楼层
同求
GMT+8, 2025-12-21 13:05 , Processed in 0.064017 second(s), 4 queries , Gzip On, Redis On.
